Replacement maf
Turned out the MAF I had bought has a broken burnoff wire
So rather than hope that a replacement or even a Cardone unit might work, I went with a brand new AC Delco MAF. This one had the correct BOSCH markings and the correct GM part number. Installed it, cleared the codes, started the engine and everything worked fine That was the good news. The bad news was that the AC Delco part came to just over $725.00
And that was my cost at the shop. But the MAF error codes stopped after that and the car ran fine.
https://www.corvetteforum.com/forums...-i-got-ww.html
I had the infamous Code36 - changed ECM, relays and used 6 MAFS!!
all the MAF's I used had Bosch part numbers on them, most were remanufactured.
Once I stopped "groping around in the dark", I got into the ECM with help from guys on here and discovered that the Burn Off voltage was out of spec and that's what was causing the ECM to show the Code 36.
Interestingly ALL the MAF's would send an out of spec voltage to the ECM. Some were 0.5 volts, some 1 volt, but all outside (above) the acceptable range for the test.
My conclusion was that there was nothing wrong with the wiring, ECM, relays etc. It was the MAF that was sending a too high a voltage to the ECM.
The choice I had was to keep throwing MAF's at the car until one finally sent the correct voltage to the ECM or disable the error reporting of Code 36.
And that's what I did - the burn off still happens, the ECM still gets the results of the test, it's just that it doesn't set the Error code and therefore the SES light stays off (unless there's some other problem).
My advice would be to find a workshop that can "see" (data log) the Burn off test, so you know why it's setting Code 36.
Good Luck!!
I got a brand new one from these guys in the UK about 5 years ago for $250 exchange. I bet you can source one in the USA easily enough. Its used on various cars, but if you ask a Corvette parts supplier, its usually $$$!!
http://www.airmassmeters.com/
Where is the burn off relay? This on driver's side front wheel well? sounds familiar to me but I'm not sure if I replaced this prior. As of today I have a code 36
