Irratic temp readings
Old Apr 18, 2016 | 04:12 PM
lectroglide's Avatar
lectroglide
Default Irratic temp readings
92 C4 135k miles, was out driving around yesterday with the outside temp around 80, I knew something was wrong when the temp gauge and digital kept jumping back/forth from 192 215....
as of right now just checked both tanks, recovery is where its spose to be and so is the black top tank, I don't get it, any suggestions??
Old Apr 18, 2016 | 05:09 PM
antfarmer2's Avatar
antfarmer2
Any air in the system that needs to be burped?
Old Apr 18, 2016 | 05:24 PM
lectroglide
is their a thread here on how-to or can someone here tell me hows its done thanx
Old Apr 18, 2016 | 05:36 PM
John A. Marker's Avatar
John A. Marker
Sounds more like a thermostat issue. Not fans since they come on at about 228 or so. Have you checked in front of radiator to be sure that all the debris is cleaned out?
How old is coolant?
Old Apr 18, 2016 | 05:43 PM
lectroglide
How old is coolant?
coolant is a yr old , will check for radiator blockage
Old Apr 18, 2016 | 05:48 PM
antfarmer2's Avatar
antfarmer2
My 94 has two bleeders but I just jack it up to make the cap the high point. You need to take the top shroud off and clean good. Might just be a plastic bag flopping around in there. They are big vacuum cleaners.
Old Apr 19, 2016 | 05:32 PM
lectroglide
just now getting under the car to see for blockage but have decided to have a complete flush done,.......... the car has green coolant should I stick with that or go to something else?? also am not sure what temp the thermostat is rated for so should their be a standard heat range it opens at?? thanx
Old Apr 19, 2016 | 05:43 PM
antfarmer2's Avatar
antfarmer2
I believe 180 stay with what you have with the coolant and pull the knock sensors out or you will leave a bunch of crap in there. Just pinch the connectors with your fingers.
Old Apr 19, 2016 | 06:13 PM
lectroglide
just got an estimate re coolant flush so I ask the guy if they did a complete flush Including the block he said they run fresh coolant thru the motor till its the fresh color but didn't mention anything about knock sensors, should I be concerned or just go with the flush? thanx guys!
Old Apr 19, 2016 | 06:50 PM
don hall's Avatar
don hall
Your '92 has two knock sensors in the bottom of the block. They should be removed for a complete flush.
The bottom of the block is a sump for sediments. Just draining coolant does not rid/clear the block of sediments.
Not only should the knock sensors be removed, but
water under pressure should be directed into the sensor holes to flush the block. Most shops will not do a complete flush, only drain the coolant.
It is suggested that the knock sensors be replaced with new, as they are probably the originals.
Your '92 has the LT1 engine, which is self-bleeding.
No need to be concerned with air in the system after refilling with new coolant.
The gyration of the temp gages may not be solved with a coolant flush, but it is a start.
Old Apr 19, 2016 | 07:44 PM
antfarmer2's Avatar
antfarmer2
What is the point of flushing if your going to leave a gallon or so of crap in it? I always change the sensors. Many do not agree if they want reuse parts it is their car I am not doing it. Torque is very important 14 lb if I remember right. Do not get your opti wet!!!!! I jack up the car to make the cap the high point and let the air bubble out my 94 has two bleeders not sure on yours.
Old Apr 19, 2016 | 08:00 PM
lectroglide
like I said earlier, the shop did not mention anything about the knock sensors even when I brought it up, that being I will definitely make sure they know!
Old Apr 19, 2016 | 08:10 PM
antfarmer2's Avatar
antfarmer2
Better watch them
Old Apr 20, 2016 | 07:07 PM
lectroglide
need to clarify something re the burping process, put the front end up on stands, run the motor for few min. then shut it off and it should get any air out , is that right???
and BTW am getting scepticle about a flush cuzz I just had it done last yr and have only put 5k miles on since, so gonna start with a new Tstat
Old Apr 20, 2016 | 08:03 PM
don hall's Avatar
don hall
The LT1 is self-bleeding.
If you don't believe me, jack the vette into a vertical position, and stand on your head naked on the front lawn.
When the police arrive, urinate on their vehicle. Done.
Old Apr 20, 2016 | 08:45 PM
lectroglide
perfect!!! will refer them to your post when they show up
Old Apr 20, 2016 | 09:25 PM
don hall's Avatar
don hall
Excuse the sarcasm, but you were provided an answer in post #10. You either didn't bother to read my response, or decided it was worthless.
To Irratic temp readings
Old Apr 20, 2016 | 09:32 PM
antfarmer2's Avatar
antfarmer2
I jack up the right rear of my 94 or you can fill it or open the two bleeders till the air comes out. Unless you took the knocks out it was never flushed right.
I have the utmost respect for Seabright but disagree with the self bleed. It can still keep a air pocket by the thermostat that is why there are two brass bleeders.
Old Apr 20, 2016 | 09:35 PM
lectroglide
I jack up the right rear of my 94 or you can fill it and open the two bleeders till the air comes out.
thanx for the respectable reply
Old Apr 20, 2016 | 10:56 PM
don hall's Avatar
don hall
I've owned C4s for over 16 years. There are few, if any, C4 problems that haven't been discussed on this forum.
If you had taken the time to do a search on 'overheating', you might have found 500 threads that provided answers to your concern. Instead of suggesting that you perform a search, you were provided the courtesy of suggested solutions.
You decided that your 'overheating' problem was unique, so you started your own thread, eschewing
the numerous solutions others have provided the past 24 years.
If antfarmer wants to jack his vette to bleed the cooling system, so be it. That is an ignorant suggestion, but seems to be to your liking.
