Procedure for changing the brake fluid?
Old Sep 5, 2002 | 04:26 PM
Derf's Avatar
Derf
Default Procedure for changing the brake fluid?
Brake fuid is getting dark, read it should be changed. Is this a big job??? Any help would be appreciated. Thanks
Old Sep 5, 2002 | 05:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Procedure for changing the brake fluid? (Derf)
MAD has a pump to aid in doing that job or you could do it the same way as bleeding the brakes, just continue till new fluid comes out.
I feel the biggest deal with this job is the danger of breaking off a bleeder screw in a caliper.
[Modified by 65Z01, 3:21 PM 9/5/2002]
Old Sep 5, 2002 | 06:02 PM
chuckster's Avatar
chuckster
Great timing...
I plan to do this this weekend. I am using Valvoline Synthetic
I will just use my 13 year old foot to pump for me... Be sure never to press the pedal too far or you will damage the seals in the M/C
Bleed in this order...
1. RR
2. LR
3. RF
4. LF
The rationale is to bleed farthest to closest
To Procedure for changing the brake fluid?
