1994 starter
Old Apr 22, 2016 | 12:06 PM
mrodoc's Avatar
mrodoc
Default 1994 starter
So, my car has been apart for 4 months, can swap, headers, etc. Today I went to put the starter in. There was a shim between starter and mount plate when I took the starter off. I can't find the shim. Is this important? Should I try to install it without the shim? It was the thickness of a standard washer.
Old Apr 22, 2016 | 12:13 PM
WVZR-1's Avatar
WVZR-1
The typical GM shim is .015 (.38mm) I believe. You could confirm the fit of the drive to the flywheel, just go for it OR ......
Old Apr 22, 2016 | 12:16 PM
s carter's Avatar
s carter
kind of if needed it's there for starter ring gear mesh/spacing. you can try running without it but if the tolerance is to small you may get gear clash or the starter gear may not disengage easily.
if it had 1 I would recommend finding it or replacing it should be available at most part stores
Old Apr 22, 2016 | 01:07 PM
antfarmer2's Avatar
antfarmer2
It was put in there for a reason.
Old Apr 22, 2016 | 09:15 PM
Purple92's Avatar
Purple92
As previous posts have pointed out - GM didn't install that shim because they had a few hundred thousand lying around and were looking to get rid of them... BUT your starter and ring gear are no longer new, so it's possible that with some wear on the gear teeth - the shim is no longer needed.
If you look in the good old FSM - they say that you should be able to insert a 0.5mm wire between the tip of the ring gear tooth and the root of the starter gear tooth (with the starter drive extended). If you can do so without the shim in place you should be good to go... If you can't - see if you can find a starter / alternator place around - they should have those shims lying around - or buy a cheap feeler gage set and do what you have to do to "make a shim".
To 1994 starter
