Radiator/Sensor
Old May 2, 2016 | 11:05 AM
CT54531's Avatar
CT54531
Default Radiator/Sensor
Just replaced the original radiator in my '87 C4. Went smoothly but...always a but...
What is the sensor(?) just below the upper oil cooler line into the passenger side of the radiator. The 'plug/clip' end into the radiator was a tight/very snug fit in the original but is quite loose in the replacement radiator - loose enough that there is a small drip of coolant from it. Very small but a drip nonetheless.
Anyone experience this. Will high temp sealant be enough to correct? A sleeve of some sort?
Old May 2, 2016 | 12:27 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Once that sensor is cliped in, you'll be lucky to remove it without breaking it.
Give it some time to settle or just buy a new unit.
Old May 2, 2016 | 12:36 PM
HAD2HAV2's Avatar
HAD2HAV2
It's the Low Coolant sensor. One of the clips broke off when I remove it from my old radiator. Had to buy a new sensor.
Old May 2, 2016 | 01:06 PM
CT54531's Avatar
CT54531
Ahhh, low coolant sensor. Makes perfect sense (no pun intended). Yes it was difficult to get out but it's okay. Just the opening in the new radiator seems bigger so I don't know if getting a new one would be any different.
I see Mid-America has them . Anyone else, do you know?
Thanks very much for the responses.
Old May 2, 2016 | 02:37 PM
HAD2HAV2's Avatar
HAD2HAV2
Can you find a fatter O-ring to replace the one on it?
Old May 2, 2016 | 04:50 PM
CT54531's Avatar
CT54531
Funnily enough, that thought was floating unformed (seems to be happening a lot lately) in my brain for a while but your suggestion brought it out. I thought I had some nice small o-rings in the garage but will need a trip to the store. I think that'll work, though. Thanks again.
Old May 2, 2016 | 05:38 PM
WVZR-1's Avatar
WVZR-1
Just buy a new level/low coolant sensor and be done with it. You'tweaked the retaining tabs and you know it's a "leaker" so why ask for more aggravation.
Old May 2, 2016 | 06:08 PM
JrRifleCoach
Thats the ticket!
To Radiator/Sensor
