1988 vert
Old Sep 6, 2002 | 10:54 AM
halver's Avatar
halver
Default 1988 vert- parasitic load on battery
phantom load on battery will drain dead intwo days. it is driving me nuts has delco sound system with calcell 6disc cd head unit was wired to un switched source, disconnected it but, still have problem. i have checked lights,doors etc. no alerts on display any suggestions, i think there is an amp somehere wired unswitched, but can find nothing..a beer to the guy that solves this :cheers: :confused:
[Modified by halver, 2:57 PM 9/6/2002]
Old Sep 6, 2002 | 11:24 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 1988 vert- parasitic load on battery (halver)
Look under the right hush panel and under each rear tray for the phantom.
If that fails, pull the pos. battery terminal, hook up a DMM in AMPS mode in series with the leads and in turn pull each fuse till the current load drops noticably.
