lacking engine performance 1984 vette
Old May 2, 2016 | 02:58 PM
alcali's Avatar
alcali
Default lacking engine performance 1984 vette
Hey guys im curious as to why my 84 cfi lacks some power Ive tried finding what the idle should be at... dont know, also I plan on adjusting my rockers, and I need the car running to drive to work so I popped some spark plugs in I didnt gap them I didnt know.if I had too because ive heard some plugs come gapped but any suggestions as to why im missing power sometimes ill floor it and the car just wont go like it should and sometimes ill floor it and ill go flying so any suggestions as to what they problem may be would help thanks
Old May 2, 2016 | 03:27 PM
Hot Rod Roy's Avatar
Hot Rod Roy
How long have you owned the car? Is this a new problem? Does the engine start and idle okay? There could be several causes for your poor performance, but my first guess would be a dirty fuel filter. Has it been changed recently?
Can you show us a picture of the tips of the spark plugs you removed from the engine?
Old May 2, 2016 | 04:16 PM
divotdug's Avatar
divotdug
Agree it could be clogged fuel filter. Could also be a failing fuel pump, dirty injectors or a dozen other things.
As a rule of thumb you should always check the plug gap on new plugs.
As already asked, is this a new car to you and is it a new problem.
Old May 2, 2016 | 05:05 PM
Silver96ce's Avatar
Silver96ce
Far too little information - how many miles; how many miles since last tune-up; last tune-up- what was replaced; new gas or sitting with old gas for a long time; etc.
As a potential answer, make sure the following is either new, in good condition or replaced:
1. Pull spark plugs and properly gap them (NEVER install spark plugs without checking gap/gapping them);
2. Spark plug wires;
3. Distributor cap and rotor;
4. Coil;
5. Gas filter;
6. fuel pressure/two fuel injectors;
7. vacuum lines;
8. Air filter.
If it is going to be a daily driver, there is a lot more to be checked/inspected/serviced but that is up to you.
Old May 2, 2016 | 07:23 PM
alcali's Avatar
alcali
The car has been driven for a few months I dont feel the rough idle everybody talks about I have an 85 fuel filter in I put before started driving the plugs were new they came out of my friends 68 elcamino but the car was sitting for twelves years never started it was alot of work getting her going but she runs good I didnt replace the spark plug wires I didnt get the timing done im going to fix valve cover leak it may have an exhaust leak but shes a good car engines strong also I dont know if injectors are going bad or not but ive put cleaner in and gas is coming out crystal clear
To lacking engine performance 1984 vette
