85 erratic idle when warmed up
Old May 8, 2016 | 06:12 PM
crzytnmn's Avatar
crzytnmn
8th Gear
Default 85 erratic idle when warmed up
I have an 85 corvette the car just doesn't want to idle once it has warmed up. It has the a/c and a.i.r. delete, a Taylor throttle body spacer, I have replaced the IAC, TPS, and the MAF sensors, I'm stuck, any help would be greatly appreciated thanks!
Old May 8, 2016 | 06:49 PM
s carter's Avatar
s carter
Have you looked for Vacuum Leaks? also if your O-2 Sensor is not working correctly it can effect your Idle. O-2 Sensor can and do wear out with 30 plus year old cars so if you know it's been replaced,tested and working great. If not I would look into it.
Has the Cam been replaced? if so was a too Radical a cam installed,To much above Factory can Greatly Effect Idle.
Old May 9, 2016 | 02:34 PM
Kevova's Avatar
Kevova
Codes? Have you reset the min air rate and tps? EGR on at idle? Are throttle body bores clean? Carbon build up can cause idle troubles
Old May 9, 2016 | 02:58 PM
aklim's Avatar
aklim
I don't know if the TB spacer might have affected the IAC by blocking it off or something. Start with the simple. Get that dead weight off. It doesn't do anything more than lighten your wallet from what I have seen in people who have had them.
Next, why did you replace the IAC? Did you take the housing off and the TB off and clean all the passages? Did you change all the gaskets?
If you have already done that, hook up a scanner and see what the IAC counts are.
Or we can simply start guessing and replacing parts till something works.
Old May 10, 2016 | 10:32 AM
WW7's Avatar
WW7
with aklim, hooking up to a scanner will show you what sensors are working properly, and which aren't...Like mentioned above , with these cars you either hook up to a scanner , or throw parts at the problem until you either get lucky , or go broke.....WW
To 85 erratic idle when warmed up
