throttle performance switch
Old Sep 6, 2002 | 06:37 PM
guywade's Avatar
guywade
Default throttle performance switch
Throttle performance switch, from MAD, anyone tried this , does it really work? TIA to all supposed to increase max, fuel, timing, and throttle response.
Old Sep 6, 2002 | 06:41 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: throttle performance switch (guywade)
not worth the money. search for this, it has been discussed in the past!
:D
Old Sep 6, 2002 | 06:42 PM
ZylaRace's Avatar
ZylaRace
Just another means of seperating you from your $.
Same as pushing the pedal harder.
Save the $, push the pedal.
Old Sep 6, 2002 | 06:43 PM
bogus's Avatar
bogus
it is supposed to increase throttle response by tricking the computer into thinking it has greater throttle voltage than normal.
it is a trick... but whether it works, is hard to say... I have not tried it.
Old Sep 6, 2002 | 06:44 PM
Marcho Polo
Former Moderator
http://forums.corvetteforum.com/zerothread?id=201594
http://forums.corvetteforum.com/zerothread?id=154002
:cool:
Old Sep 6, 2002 | 06:47 PM
guywade's Avatar
guywade
thanks guys , in 2 minutes or less i know its f__king worthless
thanks again :cheers:
Old Sep 6, 2002 | 07:04 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I put one on my '84 crossfire....it works...can't say anything bad...
but maybe all the others know what they are talking about more than me?????
Anyway it works...
:smash:
Old Sep 6, 2002 | 07:06 PM
Darrell G's Avatar
Darrell G
I bought one from MAD. Everytime i did a WOT, it gave me a code error. I can't remember the number, but i think it was a throttle position switch error. Mad sent me another one, but same problem. I even replaced the TPS but the problem followed the performance switch. They were nice and gave me a refund no problems, but it's a piece of crap.
Old Sep 6, 2002 | 08:02 PM
pwrful c4's Avatar
pwrful c4
I used one on my 1988 it made no difference.
Old Sep 6, 2002 | 09:38 PM
jstkrsn's Avatar
jstkrsn
Got one on my 92 LT1. Can not tell any difference. Luckily someone gave it to me, so it was worth the price. :D :D
Old Sep 7, 2002 | 02:55 AM
ACEMG73's Avatar
ACEMG73
Had one on my 88. Did'nt notice anything. Took it off, adjusted my my tps voltage properly, and now it has better throttle response. I put the switch on again just to see and still does nothing. My advice, manually set up your tps and will will perform better at both idle and wot. I just wish a year ago I new what I know now when I bought the switch. I would'nt even sell it to someone. I'd be ripping them off. :chevy
Old Sep 7, 2002 | 03:59 AM
vader86's Avatar
vader86
junk
Old Sep 7, 2002 | 04:37 AM
oldace84's Avatar
oldace84
Default Re: throttle performance switch (vader86)
Baloney...Baloney...salamey...
figue where you are comming from.........are you afraid of the truth....
ha...ha...
tony :bs
Old Sep 7, 2002 | 09:34 PM
84 BRONZEBOMBER's Avatar
84 BRONZEBOMBER
It was in corvette fever on an 84. On a stock 84 I think they got 12ft/lbs of torque. But they said if your car is modified you might get different results. I put one on my car because the 84 needs all the help it can get. I notice it would feel like it was at wide open at about 80% throttle. I hope it helps It can't hurt. I hope these magazines are not lying to us to keep there adds in there magazines.
Old Sep 8, 2002 | 01:41 AM
MrNuke's Avatar
MrNuke
Default Re: throttle performance switch (84 BRONZEBOMBER)
Odd.. It's not supposed to be able to give you more HP/TQ, but fool the computer into thinking you are at WOT at lower throttle.. Just FLOOR the car and be done with it.. :lol:
Old Sep 8, 2002 | 01:59 AM
gbfan10's Avatar
gbfan10
Default Re: throttle performance switch (MrNuke)
When I purchased my vette early this summer, It had one of these installed in it. Think I might take the thing out now, after reading this..
Old Sep 10, 2002 | 03:28 PM
oldace84's Avatar
oldace84
I put one on my '84 also.....I'm happy with it....
Like you said we need all the help we can get..
tony :smash: :smash: :smash: :smash:
To throttle performance switch
Old Sep 11, 2002 | 04:59 PM
Kendall's Avatar
Kendall
Its supposed to send a WOT signal when the throttle hits about 1/2. Not worth the money. I took mine off. Can't tell the difference.
Old Sep 11, 2002 | 08:47 PM
84 BRONZEBOMBER
Default Re: throttle performance switch (gbfan10)
Thats what the magazine said they used a dyno and came up with that. :p:
Old Sep 11, 2002 | 09:08 PM
ACEMG73's Avatar
ACEMG73
Think about this? When you hit the gas 75% you should have around 75% power (let's just use that as a reference). With the performance switch on it fakes the ecm to wide open throttle at 75%. So to a point their correct. At 75% gas you would have more power than without the switch. It's just a matter of how you look at it I guess. And that's how they back up their estimated gains. So without the switch you have to push the pedal all the way down to get 100% w.o.t. Pretty slick huh?
