I would like to know if my electronic heater a/c control panel is working correctly?
When you start the engine it automatically switches cycles to the "AUTO" function.
Is that normal?
1988 base model, manual trans. Z51
Reason: forgot to put 88
If you shut the system off before you shut down the engine, your AC system should not come on when you start your car.
When I disconnect my battery and reconnect it and start my 88 C4, the AC system will automatically come on.
So if you do not turn off , it will go into auto mode when you start the car?
