O2 Sensors .....
May 16, 2016 | 12:00 PM
O2 Sensors .....
So where is the CF consensus on brand of replacement o2 sensors ??
I tend to gravitate toward AC Delco parts but on this issue its certainly possible these may not be the best replacement parts.
So lets hear it .... Rumor, hearsay, popular opinion, experiences, and of course... facts.
May 16, 2016 | 12:05 PM
May 16, 2016 | 04:15 PM
I suspect many brands will perform equally well.
I don't have a great amount of experience with different ones, but on my C5 I had an AC Delco fail at about 1 year. I replaced it with a Bosch and it has been fine for 3 years and counting.
May 16, 2016 | 05:21 PM
Bosch was cheaper than Delco so Bosch.
May 16, 2016 | 07:03 PM
Denso is good and so is Bosch
May 16, 2016 | 07:07 PM
Quote:
Originally Posted by
DanielRicany
I agree but it seems like it is more stocked at the local Auto parts places so I usually go with Bosch. I switched to the heated ones.
May 16, 2016 | 07:15 PM
aklim
That's what I was waiting to see if someone might mention the change of the "single wire" to heated. That's certainly I believe the correct move. I don't know that there's a tendency to lean towards any particular brand but Denso and Bosch seem to be local choices. - most in this area seem to use or prefer the Denso. One guy makes the decision and the rest "follow". If he suggests a different brand next week then they'll likely follow!
For your install did you buy the connector and adapting harness or create your own from scratch?
May 16, 2016 | 07:53 PM
Neither. Got the sensor for a later model that had heated and the matching pigtails and put it in
May 16, 2016 | 08:01 PM
aklim
Well I'd think a "pig-tail" amounts to a connector and then you "cut/splice".
May 16, 2016 | 09:15 PM
WVZR-1
True. To be exact, I will solder instead of butt connect
May 17, 2016 | 07:31 AM
When I made this thread I had completely forgotten about Bosch. I think that's what ill go with....
