85 coolant system flush
I am looking for advice on the best and proper way to flush my cooling system. I've read about many different ways and figured as always I would get the best advice from the forum. I'm sure there are posts here , but I could not find them. Thank you!!
Put the block plug back in and the knock sensor back in. Close the radiator petcock and fill with coolant. With the 85, you need to jack up the front end as high as you can get it and place on jack stands or blocks under the wheels to burp the coolant system. Start the car and let the coolant circulate and fill the radiator as the system heats up.
on my 85, i used a funnel and directed the squirt as best i could downwards to the catch tub. wear old clothes!
as for torque on the ks, its 15lbs ft and just go easy on the sensor.
i never replaced mine, i used pipe dope on the threads, just on the bottom few, not too much, all is well.
if u have the dough replace the ks and buy the gm paste.
to unscrew the ks, , you need to first pinch the plastic wiring plug but placing a thumb and pointer finger on the flat edges while pulling. its sort of oval shaped. you pinch the long axis, which flares the short axis, and you can pull the plug off easy. then you will need a relatively deep 7/8" socket to back out the ks. go easy. hold the socket perfectly perpendicular to the 45 degree angle that you will see from teh block. you don't want it slipping and damaging the unit, its an acoustic microphone basically. be easy on it if you plan to reuse it. i did. and you will need to remove a couple small bolts along the oil pan rail. not bolts that hold the rail on, but bolts that hold the protective shield in place. i think they are 10mm.
it will make sense when you look at it. good luck and report back! take a picture of how nasty your coolant is.
oh, and the petcock (threaded drain plug) on the rad is the rear, bottom, passenger side.
if u r a z51 car u will have the oil cooler which is on the driver side opposite the knock sensor with coolant hoses running to and from the cooler which is between the filter and the block. u could unplug the coolant lines. i wouldnt. just drain replace petcock, drain block via the ks. refill. repeat if your fluid is still dirty.
