Brake pad preference?
Old May 23, 2016 | 11:30 AM
wildbill426's Avatar
wildbill426
Default Brake pad preference?
I have a 1991, basically stock; the pads are good but they exhibit some fading I'm not crazy about and I'm thinking some of that may be not that they're worn, but that they're old. I drive this about 3,500 miles/yr (car just went over 60K) and drive pretty conservatively. So, when I get pads, do I go to GM parts, or perhaps aftermarket; if so what brand? I used Ferodo's on my race car (I had a dragster) and loved their performance and wear. I am completely open to suggestions!
Old May 23, 2016 | 04:51 PM
DGXR's Avatar
DGXR
You drive pretty conservatively, have good brake pads, and still get brake fade? Does not make sense to me unless... there is an existing problem with the brakes that no brand of pads will fix.
Old May 23, 2016 | 05:32 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
If you find no flaws in your system and are in need of new pads take a look at the Carbotech 1521 pad low dust, quiet and will out perform the OE on this vehicle.
Front: $135 Rear: $120
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To Brake pad preference?
