Oil Filter Bypass Valve
Old Jun 6, 2016 | 08:51 AM
Cajun CB's Avatar
Cajun CB
Default Oil Filter Bypass Valve
Can the bypass valve be replaced in a 86 Corvette L98 base?
The FSM says that the valve and adapter must be replaced as a unit. Does anyone sell this unit or just the valve?
My C4 has low millage (34,000 mile garage queen). My oil pressure dropped suddenly to 39 PSI hot at 70 MPH and 14 PSI at idle. It was in the 50's and 60's. I have not valve train noise.
I first thought it was the sender. I replaced it with the exact same results. I do not want to install a mechanical gauge.
Old Jun 6, 2016 | 08:59 AM
PatternDayTrader's Avatar
PatternDayTrader
If there is even a problem then it would be related to the oil pressure relief valve. This is part of the oil pump. I would verify with a mechanical gauge what you think the electrical gauge is telling you. Personally I don't think 40 psi is all that abnormal.
Old Jun 6, 2016 | 09:04 AM
WVZR-1's Avatar
WVZR-1
You mention "base" so it's assumed you don't have the oil cooler/heater option. Is that correct? If that's correct just buy the filter mounting adapter and give it a try. Very straight forward install for sure. A "fix"? Likely not but if it's reassuring then "just do it". The adapter by-pass isn't a control device that offers up visual changes in pressures.
***I'd think maybe a sump/pick-up issue maybe more likely - you could respring the oil pump if you wanted and attempt that also OR you could just do the pump! The spring (relief/regulating)) in the pump could be purchased separately. Still available? Don't know - it was the same as many GM applications in many other engines.
*** I meant to mention and forgot - there's much that needs considered. Is this a higher mileage untouched original engine? A higher mile that's been maybe been thought to be "rebuilt" or had internals serviced? You might consider supplying "known resistance" to the gauge and confirm it's accuracy at advertised resistances. It's all in the FSM I believe.
Old Jun 6, 2016 | 10:41 AM
Cajun CB's Avatar
Cajun CB
Carfax confirmed the millage as low.
The engine does have a factory oil cooler.
Old Jun 6, 2016 | 10:47 AM
WVZR-1's Avatar
WVZR-1
CARFAX can't "confirm" the "low mileage" - only you can or the previous owner maybe with "documentation".
Were it mine and I wasn't concerned with originality but instead "reliability" I would likely remove the heater/cooler as required then add the base filter adapter and move on. You still have to confirm the gauge, your new sender likely against a mechanical but I see no reason to retain the heater/cooler for other than "originality" purposes. That's your decision !!!
Old Jun 6, 2016 | 11:27 AM
PatternDayTrader
Originally Posted by WVZR-1
you could respring the oil pump if you wanted and attempt that also OR you could just do the pump! .
with this 100%
Old Jun 6, 2016 | 01:20 PM
BOOT77's Avatar
BOOT77
They make non-bypass oil filter adapters or you can mod yours(google it), but if your filter has a bypass and some do then it's the same thing.
edit: Not to be used in cold weather the oil will be too thick.
Old Jun 6, 2016 | 01:27 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86 has 100K plus. The oil pressure is as you have indicated using Mobil syn.
Rule of thumb for oil pressure is 10 PSI for each 1000RPM.
Old Jun 6, 2016 | 01:52 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Can the bypass valve be replaced in a 86 Corvette L98 base? My oil pressure dropped suddenly to 39 PSI hot at 70 MPH and 14 PSI at idle. It was in the 50's and 60's.
The bypass valve has nothing to do with your oil pressure. Its only purpose is to allow oil to bypass the oil filter if the differential pressure between the inside and the outside of the oil filter element exceed its rating. This might be caused by poor maintenance (clogged filter) or extremely thick motor oil (-40* environment). Neither of these is likely! Even if your bypass valve were stuck open, you'd never know it unless you would dissect your oil filter after many, many miles, and find that it was like new!
Old Jun 6, 2016 | 03:21 PM
aklim's Avatar
aklim
http://www.ebay.com/itm/Sbc-Chevy-Oi...xWKPUQ&vxp=mtr
Old Jun 6, 2016 | 04:40 PM
Cajun CB's Avatar
Cajun CB
It is my understanding that the bypass valve directions flow to the filter back into the oil pan if pressure is too high OR if it is malfunctioning. Oil pressure is measured downstream of the filter. How can it not have an effect on oil pressure indicated if part of the stream is bled off back into the pan.
I am concerned that the valve has malfunctioned with trash under the seat or broken spring. I plan on inspecting it. I just wanted to know where to find one if it proves defective.
Old Jun 6, 2016 | 04:45 PM
bjankuski's Avatar
bjankuski
Hot Rod Roy is correct, the bypass valve at the filter housing only bypasses the oil to the filter, if the filter is clogged or too restrictive. The oil is bypassed around the filter but still dumps into the main gallery feeding the camshaft and lifters so you still have oil pressure. If the bypass is stuck open the oil will not be filtered but you will still have pressure.
Old Jun 6, 2016 | 06:44 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hot Rod Roy and bjankuski are right.
Old Jun 6, 2016 | 07:01 PM
WVZR-1's Avatar
WVZR-1
I understood the engineering and understand HRR/others comments. I mentioned the "just do it" since the OP felt he wanted to and it's as simple as a filter change and cheap BUT THEN he complicated it with the mention he has the heater/cooler. Certainly makes it more difficult!
If he does it he convinces maybe himself!
He could have done some fairly straight forward diagnostics before ever doing his 1st replacement of the sender!
Old Jun 6, 2016 | 07:14 PM
PatternDayTrader
I agree. ... ask me how I know !
Old Jun 6, 2016 | 10:00 PM
jv9999's Avatar
jv9999
The odds of it being an electrical gauge problem in your 30 year old queen are probably 10X the odds of it being a mechanical one. Especially if you have no other symptoms such as noisy lifters.
Old Jun 7, 2016 | 12:02 PM
383vett's Avatar
383vett
Reading the op's original post, I don't think there is a problem at all. Oil pressure isn't normally 50 or 60 psi while cruising when the motor is hot. Maybe this was before the oil temperature was at operating temperature or maybe the op was mistaken. There is nothing wrong with 30 psi at 2000 rpm with the engine warmed up.
To Oil Filter Bypass Valve
