c 4 Throttle
Old Jun 6, 2016 | 05:06 PM
Rusty Tx's Avatar
Rusty Tx
2nd Gear
Default c 4 Throttle
Ok the car hesitates to start butt will start and idles fin and will rev up When you drive for a few minuets the pedal go's away butt it will still idle gust no throttle costing down the road turn car off and re start it will run for a bit and do the same. gas stays at 35 PSI All time
Old Jun 7, 2016 | 09:38 AM
Kevova's Avatar
Kevova
Check for carbon build up in throttle body (butterflies) and IAC passages.
Old Jun 7, 2016 | 11:39 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
First post......perhaps tell us a bit about you and/or your car, so we can help you with your questions (and your spelling ).
Old Jun 8, 2016 | 12:15 PM
RWH1290's Avatar
RWH1290
2016 C4 of Year Finalist
Helps with ..Year and Engine
Old Jun 8, 2016 | 01:16 PM
antfarmer2's Avatar
antfarmer2
Year and have you ever changed the fuel filter?
Old Jun 23, 2016 | 06:26 PM
Rusty Tx's Avatar
Rusty Tx
2nd Gear
It is a 1988 with L98 and i did change fuel filter and cat is cleaned out .
Old Jun 23, 2016 | 06:31 PM
antfarmer2's Avatar
antfarmer2
I thought the pressure should be 42 down to 37 but not sure on yours. Might be a leaky pulsater in the tank if it is to low. Or weak fuel pump. Does the fuel pressure go up if you pull the vacuum line off the FPR and is there any fuel in it?
To c 4 Throttle
