throttle return spring
Old Jun 8, 2016 | 06:25 PM
wjc1947's Avatar
wjc1947
Default throttle return spring
I have a 1986 c4 the throttle does not return without help(pulling back on gas pedal) . the spring appears to be weak or just broken, are the springs replaceable or must I purchase a new throttle body? Is it very difficult or can the average guy do it at home? tks
Old Jun 8, 2016 | 06:48 PM
antfarmer2's Avatar
antfarmer2
Can you just add a spring?
Old Jun 8, 2016 | 08:38 PM
WVZR-1's Avatar
WVZR-1
If the spring isn't broken then you very likely have worn TB shaft and TB itself there's not an easy fix. If the TB blades/shaft can be confirmed to NOT be causing the bind actually this "DOES WORK"
https://www.corvetteforum.com/forums...post1563571811
Requires patience!
Adding a spring to an already binding TB generally creates greater issues!
Old Jun 9, 2016 | 07:38 AM
C409's Avatar
C409
..... Try lubing the throttle shaft with a silicone or PTFE spray ... spray while working the throttle by hand (engine off of course) . This can be done easily enough without removing the TB from the car ... just pull the intake bellows off and spray into the ends and center where the shaft passes through the body of the TB .....
To throttle return spring
