LT1 Troubles
Old 06-13-2016, 09:24 AM
twichy2011
twichy2011's Avatar
Default LT1 Troubles
I have a 1992 Corvette LT1 with 127k miles thats been giving me some trouble. The car shuts off randomly at idle, and while driving the car, some times it sounds like the car literally farts (for lack of better words) out the exhaust; smells rich when it does this and makes your eyes burn.
What I've replaced in the past 3 months:
-Optispark: MSD unit
-TPS : AC-Delco
-Intake Air Temp Sensor
-New Computer
-Plugs and wires and the coil wire
-Fuel Filter
*Everything I have replaced was tested prior to replacing and every new sensor was checked to make sure it was in spec of the FSM*
Fuel Pressure is fine and the Fuel Pressure Regulator is fine as well.
The only thing that is left related to ignition is the Ignition Control Module and the Coil. Don't think the symptoms I'm having is pointing towards that. I'm also getting no codes. At this point I'm stuck scratching my head trying to figure out the problem.
Thanks for reading and any help is greatly appreciated!
Old 06-13-2016, 10:24 AM
antfarmer2
antfarmer2's Avatar
Have your icm and coil tested if your o2s are original I would change them too. Some have had many bad MSD opti's
Old 06-13-2016, 10:38 AM
twichy2011
twichy2011's Avatar
I haven't had the coil or ICM test. The original opti failed before I replaced it with the MSD and it doesn't act like the old one did when it was bad. As far as the cool and ICM goes, would I see much of drivability issues or is it more of once it's bad the car doesn't run. Would o2's cause the car to randomly stall? I've been talking to a local shop and they mention that the cats could be clogging. Not sure if that would cause make the car stall though. Thanks!
Old 06-13-2016, 12:26 PM
antfarmer2
antfarmer2's Avatar
The cats can and will mess up the o2s too. Might be on to something.
Old 06-13-2016, 12:36 PM
dizwiz24
dizwiz24's Avatar
the 92-93 speed density cars are seriously affected by a bad o2
they will run so rich and foul the spark plugs (and cats if you dont correct the problem qui k).
eventually it will leave you with a no-start situation whn plugs foul completely.
i would plan on replacing o2's and spark plugs . may want to check and see if they are carbon fouled.
what kind of spark plugs? if they are fancy platinum or iridium they will foul quicker due to smaller tips vs. plain copper
i had this exact problem on my 93 in 2001.
it sounds like you are likely correct in thinking the msd opti is not the cause of these problems - given that you have had experience with a bad optispark and know what to expect.
this said, i hope you added a custom vent (like 95-96 units) to your msd opti or you will have to replace it sooner again.
Old 06-13-2016, 01:37 PM
twichy2011
twichy2011's Avatar
Thanks for the input! I replaced the wires and plugs about 800 miles ago. Put double platinum Bosch plugs in. When I get a chance I'll pull the plugs and check them. I'm not sure the condition of the o2 sensors. I have access to a car lift when I'm not living at school so I'll take a weekend and put it on a lift and check all that out.
Old 06-13-2016, 02:23 PM
THE 383 admiral
THE 383 admiral's Avatar
I have not. been impressed with double platinum’s. They actually foul quicker. I never have any problems with NGK race plugs.
Old 06-26-2016, 01:22 AM
twichy2011
twichy2011's Avatar
Just replaced the o2 sensors.... They were a pain in the a**. Especially the passenger side o2 sensor..... Anyways they problem is still there, may be a little better though. What now? Any thoughts?
Old 06-26-2016, 05:50 AM
antfarmer2
antfarmer2's Avatar
Did you check your cat? It will just ruin the new o2s. Did you reset the puter?
Old 06-26-2016, 10:40 AM
twichy2011
twichy2011's Avatar
I did not check the cats only because I need to drive the car tomorrow to Daytona from south Carolina and I didn't want to remove them and damage a bolt (which will mostly melt happen with the age of the car and my luck haha). Can the cat be checked while on the car
Old 06-26-2016, 11:14 AM
antfarmer2
antfarmer2's Avatar
If it was me I would spray the bolts with PB blaster a few times and heat them. Then smack the cat and listen for rattles and hope it breaks some clog loose then run it hard to Florida repeat and run it back.
To LT1 Troubles
Quick Reply: LT1 Troubles
