SYS light on
Old Sep 9, 2002 | 10:29 AM
The Rex's Avatar
The Rex
Default SYS light on
On my 96 LT4 while driving every once in a while the SYS light next to the speed will flash. When I push the guages button to scroll through options it stops and all things are normal again. It has only happened a couple of times, and when it did the SYS only flashed a couple of times then went back to normal. All the guages work(analog & digital readouts) and no dummy lights ever came on. Any ides?
Old Sep 9, 2002 | 10:30 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: SYS light on (87TRex)
Happened to me when my battery was going bad. Also, if the prom holder in your ECM has come loose, you will get a flashing SYS light, and terrible performance (limp home mode).
-Mark
Old Sep 9, 2002 | 10:35 AM
The Rex's Avatar
The Rex
Default Re: SYS light on (MarkLT1)
It has been running great with no trouble at all. It quite possibly needs a battery, it has a Napa battery now. I was going to take care of that anyway. I have gone over the connections at the ECM, but I'll double check them for good measure. Thanks for the info. :cheers:
Old Sep 9, 2002 | 12:09 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
http://forums.corvetteforum.com/zerothread?id=204358 :cheers:
To SYS light on
