I know the lower radiator hose for the earlier Corvettes has the spring in it so it will not suck shut.
But I am having a TOTAL BRAIN fart and can not remember IF GM uses a spring in the lower hose for a 1985???
I may have a 1985 that I feel may be sucking the hose shut due to it being an aftermarket hose that seems to not have a lot of structural rigidity to it when it is cold.
My '86 had a spring in the lower hose but it had major rust problems so I threw it away. I haven't seen any problems with the new hose without the spring.
I would think the hose would be stiffer when it's cold and get soft when it's hot.
cjpony parts sells different dia/lengths of springs
Shocked at how different factory/auto pts hoses differ in quality
took the originals off a 90 one ton last week, soft but real thick.
The best Gates I could find were thin and flimsy.
By pass hose from dealer, also gates but super thick and stout.
Make sure your rad. cap is correct and fresh had a hose suck shut over one before.
I have numerous springs that I take out of lower hoses that I throw away and the springs are good.
The radiator cap is new and good and pressure tested. An AC Delco RC-27 15psi CLOSED SYSTEM cap.
I hope to run it tomorrow and see what happens.
DUB
Hi
I always use the coiled spring in the lower radiator hose, I came across the same issue when one hose had a shorter spring.
Part of the lower hose would collapse blocking the flow at higher rpm,
installed the spring out of my old hose and all was good again.
I have a water pump with a curved vane impeller, not the cheap tin paddle with no sides that aid cavitation.
I doubt one of those pumps would be able to suck enough to collapse the inlet hose, however the spring is a must I even open it larger at the ends so it cannot enter the pump.
