Brake pedal soft on first application....
Anyway, car performed fine (first place in my class
), but when I drove it the next day, I noticed two "symptoms"; 1. When the ABS pump cycles after start up/during the first drive away, it's very quiet now. For the past 7 years of ownership, the pump cycling has been very loud/prominent -even with the bin lid closed. How loud? Loud enough to be heard over engine noise. Louder than the AIR pump. Loud enough that people have asked, "What what THAT!?" I've always figured that it was normal...but now I wonder if it wasn't normal and the quiet cycle now (I can barely hear it IF I'm listening for it), is what should be normal. How loud is your ABS when it cycles at first drive away?
2. My pedal is soft on first application. I'm pretty sure that my 180k mile master cylinder is bad. If I do a light pump, then apply, brakes behave normally. If is simply depress the pedal, it goes about 1/2 way down before getting firm and I sometimes get a brake light on. As I depress the pedal on that first application, pressure does start to build at the point it should, I can feel the pads hit the rotors...but then it's as if some seal gave way, pedal goes soft for another 2" of travel or so, before building pressure and braking in earnest begins. Anyway, I can diagnose the soft/first pedal part fine -I only posted in case someone felt that there was a correlation between the now quiet ABS cycling, and the pedal. I'm guessing that the ABS shouldn't be loud, and has always needed to be aggressively used...and I haven't done that until now.
Try a powered brake bleeder and flush the lines with it and I bet it goes back to the way it was.
Let me see if I can find the link to the one I bought. Works miracles on abs issues like that.
https://www.amazon.com/vidaXL-Brake-...437800&sr=1-72
If someone had of told me this before I bough the thing I wouldn't of believed them but it really does that good of a job. It probably even cleans out trapped air in the wheel cylinders too. Thing really works. That fill bottle that comes with it that keeps the reservoir topped off is handy too and the key to how it gets so much fluid thru fast enough to clean out the system.
As good a theory as any but it could be something else too. Its worth a shot power flushing. It has really solved several nagging problems I had of late with different vehicles here.
The worst was my 1999 f150 pickup. Its brakes sucked since buying it from a friend. Spongy till pumped at least once. No amount of normal bleeding helped. I even replaced the abs unit since it was acting a bit weird too. Still same spongy pedal.
I flushed it probably almost 20 times total between attempts before and after the abs unit swap.
One bleed with that gadget and it has a full brake pedal now. Horrible crap out of the lines too when I flushed with it.
Your mileage may vary so to speak but I wish Id of had that thing 20 flushes ago
i dont want to get off topic but i was curious why this one is so good crowz? how would it suck other crud out yhat other hand pump vacuum systems would miss?
1. You never get that much of a pull since your "pumping" up the vacuum applied to the line.
2. Its either problem #1 or its more a pulse effect in place of a steady constant pull. (pulls when you squeeze and lets off before you get another squeeze on the pump handle)
3. I give out long before the jobs done
100+psi of air shooting thru causes a nice constant and strong vacuum effect to blast the fluid thru stronger and more even than the hand pumps I had tried before. The lever on this one is not a pump. Squeezing the handle on this one causes the air compressors air to shoot thru the handle creating the vacuum. Squeeze till bled then let go of the handle.
It catches the old bad fluid in the tank that the handles on the other bottle you fill with fresh fluid and close the valve on it. Turn it upside down into the neck of the master cylinder and then open the valve. Whenever the fluid level drops from you draining it out it auto refills it as its draining.
Scared the crap out of me when I first bought my 86 when it cycled for the first time.
Brake fluid was low in the res. Under hard braking it would slosh/move forward in the res, exposing the rear port (front brakes) to air. It ingested air.
Bled out this past weekend....back to normal.
from this thread:
https://www.corvetteforum.com/forums...r-upgrade.html
