Extreme Misfire / Backfire
Old Jul 8, 2016 | 08:24 AM
baileygo's Avatar
baileygo
Cruising
Default Extreme Misfire / Backfire
Morning all, I've had this 89 for 2 weeks. Starts and runs great for maybe 10 miles then all hell breaks loose. Misfires awful, will engage for a second, then misfire again. Does not quit but idles rough. Then I have to limp home. Sometimes it will regain its composure and run smooth again. Check engine flashes occasionally during these spells but not steady. Any input will help.
THX
Also noticed pressure relief from fuel filler cap when opened, normal? Never seen this before.
Old Jul 8, 2016 | 09:06 AM
ddahlgren's Avatar
ddahlgren
Tank vent plugged? Charcoal canister and whatever vents the tank?
Old Jul 8, 2016 | 11:16 AM
baileygo's Avatar
baileygo
Cruising
Checked the canister, I can move air through it. Just cleaned the cap maybe the vents in the cap were plugged.
Thx
Old Jul 10, 2016 | 10:33 AM
Vett1990's Avatar
Vett1990
baileygo,
Your "Check Engine" light flashed, let's start by reading the stored codes and start your troubleshooting process at that point. That way you will have a logic track to follow.
Old Jul 10, 2016 | 11:06 AM
baileygo's Avatar
baileygo
Cruising
Originally Posted by Vett1990
baileygo,
Should the vapor canister solenoid be hot. Too hot to constantly hold? I have no way of reading codes, made an app with a mechanic for Monday am. Hopefully I won't start throwing unneeded parts at this problem.
Thanks for your input.
Dan
Old Jul 10, 2016 | 06:49 PM
Vett1990's Avatar
Vett1990
The car will provide you with diagnostic codes, do you have a service manual? If not google "diagnostic code checking on C4 Corvette". List the codes present and we can proceeed from there.
Old Jul 11, 2016 | 12:05 PM
baileygo's Avatar
baileygo
Cruising
I do not have a service manual. I had it scoped today,two different places. Both said code 34. Maf? Should I change it?
Old Jul 12, 2016 | 08:49 PM
illenema's Avatar
illenema
Find out how to clean it that Maf will have huge effects
To Extreme Misfire / Backfire
