Throw out bearing
Old Jun 25, 2016 | 09:36 AM
T Jeffery Hill's Avatar
T Jeffery Hill
Cruising
Default Throw out bearing
I have a 1990 ZR1, I believe I need a throw out bearing.. can it be replaced alone, or does it need the complete clutch kit. GM no longer has these parts.. who the best to get it from .
Old Jun 25, 2016 | 09:47 PM
Kevova's Avatar
Kevova
You don't necessarily need a clutch, but it's worth looking at while it's apart. Trans has to come out to change it. It takes just a few minutes to check disc
Old Jun 25, 2016 | 09:52 PM
WVZR-1's Avatar
WVZR-1
What leads you to believe you need a release bearing? It's certainly possible but maybe more likely if you've got a "squeal/scream" it might be the crankshaft insert(pilot bearing/bushing).
There's actual lots to look at if you've issues, a cracked fork or a bad pivot stud are possibilities.
Old Jun 25, 2016 | 10:07 PM
T Jeffery Hill
Cruising
Thanks for responding, I hear something spinning when I first Start it I push the clutch in and it stops. I was talking to another zr1 owner told him that and that is what he said.. I can feel it a little and it feels like it's coming from the transmission.. I can hear constantly when I accelerate... I thought it might be one of the four cams. I hope not..
Old Jun 25, 2016 | 10:11 PM
T Jeffery Hill
Cruising
Thanks for responding. Ok . If you live in Kansas city, do you have a mechanic here. Thanks again
Old Jun 26, 2016 | 08:20 AM
Herb's Avatar
Herb
Default Call Jim Jandik
He owns Power Torque Systems!
641-342-7446
I purchased an entire clutch from Jim. Great guy!
He also resurfaces dual mass
Flywheels!
Give him a call!
Old Jun 26, 2016 | 08:25 AM
T Jeffery Hill
Cruising
641-342-7446
Flywheels!
Give him a call!
Thanks for responding Herb, thanks for your help.
To Throw out bearing
