4+3 od @ 80% throttle problem
On to the last time I drove it I turned the OD switch to "on" and merged onto the highway. As I was trying to merge I hit the hammer only to find it bog down and the OD did NOT switch off at 80%+ throttle. HELP! Is there a sensor that can be traced? I don't think it's the console switch and it's not the fluids. The light only comes on when the unit is correctly engaged.
Thanks in advance! :seeya
My first shift into OD in the morning is becoming really slow, so I'm probably in the same boat. After the first time, all is normal again for the rest of the day. This is NOT the major rebuild involving clutches, etc, it has to do with the hydraulics.
It looks like the valve body can be removed for R&R without pulling the trans.
Thanks :seeya
Also noticed that '85 is not supposed to kickdown in 2nd or 3rd gear according to the "4+3 Overdrives" chart at http://www.4speeds.com/ which has always been correct so far. Were you in 4th gear?
If the light and the OD operation are always in sync, then nevermind the valve body discussion. It's when the light is on, but the OD is not engaging, that I would begin to suspect an internal problem. Mine waits a while (about 1") to engage the first time, even though the light is on.
If the light doesn't come on when you should be in OD, then the OD isn't getting power to activate the solenoid (they are wired together) meaning somewhere in the relay, computer, or switch circuits the signal is disappearing. Relay's the usual culprit here, mine had to be replaced recently.
I think I'm pretty much repeating what trupp said...
BTW I can't swear I wasn't in 3rd so that may have been it too, but either way I need to fix the intermittent problem.
