Pulling the crankshaft front gear to replace with double row timing gears. Any suggestions on what to look for? The box only had the cam gear, crankshaft gear and the double chain. Also are these sets a direct fitment?
not near enough info. what box? brand, part number, etc. also what year car are we talking about? from your user ID, I can only "assume" an L98. FWIW, on my 85 iron head, I replaced the factory timing chain with a cloyes double roller - direct fit and no issues. bought it at summit racing. it was about 10 years ago - don't remember the P/N, pricing info, or pretty much anything.
I also noticed that the cam timing gear has a roller bearing plate on the back. Does the old block plate stay on?
Here is a cut and paste i got from ebay detail item:
Compatibility for Billet Chevy SBC 350 Late Double Roller 9 Keyway Billet Steel Timing Chain Kit
My Vehicles
1989 Chevrolet Corvette L98 TPI aluminum heads
2 vehicle(s) matching 1989 Chevrolet Corvette.
5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
1989 Chevrolet Corvette Base Hatchback 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
Condition: New Manufacturer Part Number:
DMTRM203
Brand:
Demotor Performance
My Vehicles
DMTRM203
Brand:
Demotor Performance
were there any instructions or paperwork in the box? i'm really not familiar with Demotor or that specific timing chain set, although it "looks" to be decent hardware.
Their parts seem to have a warranty/guarantee that ends "at install" -
I didn't see any warranty information at all - see the fine print in this link regarding their claim to "quality" - as long as it's in the box and NOT installed "no problem".
if your going to install this product, just set it up at ZERO ( the crank gear) and go from there. Same with the cam gear. Someone on here suggested to install he timming cover BEFORE installing the crank seal. Said it makes for an easier install on the bottom cover/pan seal. Its a good tip.
Hopefully timing set came with instructions. The multiple keyways are for degreeing camshaft, which is a little over the top for a novice. You can easily get cam crank timing incorrect, especially with so many key ways, that normally leads to additional repairs (more money) If kit comes with no instructions, you are unsure,or do not any a "mechanic friend of the family" to help you. Return it for a standard type set with one key way. The plate at the cam stay on it keeps cam from walking back and forth in the block while engine is running. Plate is only on SBCs with roller cams. It is easier to deal with front seal while timing cover is off car. This a Corvette, not a pick up, there not a lot of space to try to drive seal in to cover with engine in car.
Never messed with a roller block but make sure the cam gear clears everything behind it, I know older blocks have to have the three oil bosses above the cam clearenced.
Was looking at pics on timing cover trick with trimmed lower lip. Can i drop the oil pan bolts without causing the gasket to leak later? Will the pan drop ok with braces intact? Really would like to leave the pan alone if possible. The timing cover kit i am using is two piece but will not install with pan tight.
personally, if I broke the (gasket) seal on the that oil pan, i'd replace that 27 year old gasket. some say you can reuse those rubber gaskets, but with age, heat cycles, and deformed surfaces set by mating surfaces, I wouldn't think so. cant say anything about the braces on an 89, but seems to me I dropped the pan on my 85 without removing the braces. either way, you're only looking at a handful of nuts and bolts. I used the fel-pro, one piece, blue silicone rubber oil pan gasket - it's been about ten years now, and still bone dry.
