Valve cover issue
Old Jul 6, 2016 | 01:31 PM
Redrod's Avatar
Redrod
Default Valve cover issue
JUST INSTALLED AFR 195 HEADS WITH 6:1 COMP ROCKERS ON MY 91 L98 CORVETTE. FOUND A NICE SUPER RAM ON EBAY AND WITH A LOT OF EFFORT GOT IT INSTALLED. MY PROBLEM IS VALVE COVERS!
INITIALLY PURCHASED PROFORM DIE CAST TALL COVERS BUT NO WAY COULD I GET THESE BAD BOYS TO CLEAR THE RUNNERS. I'M LOST AS A BALL IN TALL WEEDS! I'VE SEEN ON FORUM WHERE SOME HAVE TAKEN DREMEL TO THE EDGE THAT HIT RUNNERS BUT REALLY WANTED TO AVOID THAT PROCEDURE. SOMEONE SUGGESTED AFR V/C BUT AT THIS POINT EVERYTHING IS A GUESS! MOST COMPANIES DON'T SUPPLY MEASUREMENT DATA SO HOPING TO PULL INFO FROM SOMEONE WHO HAS BEEN THERE! I WOULD APPRECIATE ANY INPUT!
AS A SIDE THOUGHT! THIS FORUM HAS BEEN AN INVALUABLE ASSET FOR ME DURING THIS BUILD!!! THANKS YOU SOOOO MUCH.
Old Jul 6, 2016 | 07:35 PM
RWDsmoke's Avatar
RWDsmoke
I've always been a fan of buy what you want and make it fit. The hardest part of tall covers on a c4 is clearing the wiper motor.
Old Jul 7, 2016 | 08:13 AM
WW7's Avatar
WW7
The early C4s had problems with the wiper motors getting in the way, later year L98 and LT1 cars didn't have clearance problems...I have 1/4" taller valve covers on my 89 with no interference...WW
Old Jul 7, 2016 | 01:39 PM
Redrod's Avatar
Redrod
Originally Posted by ww7
the early c4s had problems with the wiper motors getting in the way, later year l98 and lt1 cars didn't have clearance problems...i have 1/4" taller valve covers on my 89 with no interference...ww
1/4" taller than stock covers?
Old Jul 7, 2016 | 03:17 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I used a drum sander to put a radius relief on the edge of my covers. It was only about an 1/8" deep relief and did not reach gasket.
You will not see it, so don't sweat it.
Old Jul 12, 2016 | 12:00 PM
Redrod's Avatar
Redrod
Gentleman sometimes we fret over nothing! Purchase a pair of Proform stamped stock height
valve covers with the intent of grinding until they fit! put the drivers side cover over the head to mark areas to grind and guess what! "THEY FIT" no cutting or grinding! I did have to remove baffles !!! Thanks you for walking me through process!
looks ok??
Old Jul 12, 2016 | 02:57 PM
383vett's Avatar
383vett
Looks nice. I ran a SuperRam for years. Great for the street/strip.
Old Jul 12, 2016 | 03:44 PM
Dt86's Avatar
Dt86
Gentleman sometimes we fret over nothing! Purchase a pair of Proform stamped stock height valve covers with the intent of grinding until they fit! put the drivers side cover over the head to mark areas to grind and guess what! "THEY FIT" no cutting or grinding! I did have to remove baffles !!! Thanks you for walking me through process! looks ok??
That looks bitchin! Where'd you get them from?
Old Jul 13, 2016 | 12:39 PM
Redrod's Avatar
Redrod
Got them from summit.
Proform 141-899
To Valve cover issue
