Radiator cooling fan...
If you look at the back side of the driver side black plastic wheel well housing you should see the coolant fan relay.
The relay socket should have a Dark Green/White wire. The ECM grounds that wire to energize the relay which then provides 12 volts to the fan.
The mechanic probably spliced a wire to the Dark Green/White wire to a switch which goes to ground when the switch is turned on.
If you want to see if the ECM can control the fan all you need to do is take a piece of wire and connect Pin A to Pin B on the diagnostic connector located above the drivers right knee.
Turn the ignition on and the fan should run.
The ECM uses the ECT sensor to determine when to turn the fan on and off. It's screwed into the front edge of the intake manifold.
The dash cluster temperature sender is screwed into the head so the two temperatures are close but not the same.
If your AC works it should also turn on the fan when the hi pressure reaches a certain pressure.
Here's a picture of the pin out for the OBD 1 connector.
