Is there a performance TPS setting?
Old Sep 11, 2002 | 05:38 PM
fullboogie
Default Is there a performance TPS setting?
Other cars with a TPS have suggested voltage settings for better throttle response. Does the LT4 have the same? Thanks for any advice.
Old Sep 11, 2002 | 05:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Is there a performance TPS setting? (fullboogie)
I doubt it; even the late L98s had fixed TPS and the ECM did an auto-determination of idle and WOT.
Old Sep 11, 2002 | 07:07 PM
quiksilver458's Avatar
quiksilver458
Default Re: Is there a performance TPS setting? (65Z01)
im pretty sure they dont.. not 100% positive though.. The ecm is programmed to detect a certain volt reading from the TPS.. If it is not in the range, the ecm uses a default air/fuel mixture an ect. for engine operation.. This typically results in "power loss" hope this helps :)
Old Sep 11, 2002 | 07:36 PM
C4-Wolf's Avatar
C4-Wolf
Many people have said that they get better throttle response out of setting it upwards of .6 - .65 V at idle. I can't verify this though.
To Is there a performance TPS setting?
