MAF question
Old Sep 11, 2002 | 06:22 PM
Dettho's Avatar
Dettho
Navigator
Default MAF question
What does the MAF really do?? :confused:
All I know is that it measures or controls the airflow...?
just a breaf explanation please!!
Old Sep 11, 2002 | 06:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: MAF question (Dettho)
Well, that's pretty much the size of it; the MAF is a Mass Air Flow sensor; it does not control air flow.
It measures the mass of air flowing through the intake in gm/sec. The L98 MAF has a range of 0-255gm/sec. It measures the mass of air flowing across several heated wires.
As more air flows the wires cool and more current is required to maintain constant temp.; it's this current (or dirving voltage) increase that is a direct measure of air flowing across the sensor wires.
These wires must be kept clean as contaminents tend to insulate the wires from the air flow and produce false readings. To this end, the L98 uses a burn-off circuit that passes a high current through the sensor wires for about 2sec after the engine is shut off. This is enough to burn off any contaminents and assure the MAF gives correct air flow readings.
I hope this is the info you were looking for.
Old Sep 11, 2002 | 06:47 PM
Dettho's Avatar
Dettho
Navigator
Default Re: MAF question (65Z01)
Thanks,
great explanation!!
Just one more :confused:
when loking in it, I can see the square shaped wires,
but there is also some metall things at the bottom of it..??
Any clue about what it is??
Old Sep 11, 2002 | 06:50 PM
quiksilver458's Avatar
quiksilver458
Thanks,
great explanation!!
probably some type of temp sensor or soemthing.. Not sure though :)
Old Sep 11, 2002 | 06:56 PM
Kendall's Avatar
Kendall
Default Re: MAF question (quiksilver458)
This is a simplification but there is a heated wire in there. Moving air cools it. This factor is measured and tells the computer how much air is flowing into the motor. The computer then takes other factors such as engine temp, throttle setting etc. and then tells the injectors how much fuel to throw at the motor.
Old Sep 11, 2002 | 06:57 PM
65Z01's Avatar
65Z01
Those are five fins for the heat sink to keep the electronics cool. There story goes that the General added them after one MAF failed during testing in Death Valley heat.
These are cut off flat when a MAF is gutted to increase potential air flow.
Old Sep 11, 2002 | 07:06 PM
Kendall's Avatar
Kendall
I just got a new GM MAF off of Ebay. On it the inside looks much different and also the screens have a definite honeycomb shape. My old screens looked like they came off a screen door.
Old Sep 11, 2002 | 07:21 PM
Dettho's Avatar
Dettho
Navigator
This forum is great!!!
Thanks!! :)
TPIS have the replacement MAF for about 250$
Gues thats better then get a new one..?
Old Sep 11, 2002 | 07:26 PM
65Z01's Avatar
65Z01
Default Re: MAF question (Kendall)
Does the new MAF have the sensor wires inside the round tube?
Old Sep 11, 2002 | 07:27 PM
Kendall's Avatar
Kendall
Watch Ebay. There is some guy that keeps selling new GM's for $75 Buy It Now. Just do a MAF search. They are the same for Trans AMs, Camaro's and Vettes
Old Sep 11, 2002 | 07:30 PM
Kendall's Avatar
Kendall
Yes inside. Some people cut the screens out. They claim to get more air that way. Other people say the screens keep the air flowing straight through so you get a better reading. Who knows.
To MAF question
