L98 MAF Replacement
Old Sep 11, 2002 | 09:35 PM
1MoorTym's Avatar
1MoorTym
Default L98 MAF Replacement
Anybody ever try to use a Granatelli MAF on an L98?
These things look enormous and if they could be calibrated properly they would flow like crazy. I'm not sure about removing screens and heat sinks on the stock MAF and thought that the Granatelli piece would by just what the doctor ordered.
What do you think ?
Old Sep 11, 2002 | 09:40 PM
scorp508's Avatar
scorp508
I wouldn't bother until you are already maxing out your stock one. At 388hp my ECM just barely shows me maxing mine out for a split second.
Old Sep 11, 2002 | 09:53 PM
1MoorTym's Avatar
1MoorTym
Default Re: (scorp508)
thanx scorp - lots more questions
Have you modified the MAF? What parameter showed you maxing out?
This 388hp was with the SR? What else did you do to the intake to open it up to feed that intake?
I'm putting ASM runners on an Accel base with a ported plenum and before I get a chip done I want to finish the intake up.
To L98 MAF Replacement
