Corsa exhaust installation tips
Old Aug 5, 2016 | 06:41 PM
Christi@n's Avatar
Christi@n
Default Corsa exhaust installation tips
Corsa exhaust is here ready to mount.
Has anyone already performed this installation on lt1 engine?
Would ask if it would possible to make it just using car ramps on rear end, and if necessary a little pair or ramps on front end.
Thanks chris
Old Aug 5, 2016 | 08:05 PM
mtwoolford's Avatar
mtwoolford
Thanks chris
I did mine with the front wheels up on ramps and the rear wheels; actually I think the lower shock mounts supported by jack stands.
to make the job easier get a couple small jacks to hold everything up, the complete exhaust system, in place where you want it befor starting to tighten the various clamps
It also seems to me one side, the passenger side to the rear of the passenger side cat was a little long and had to be trimmed; other than that it was pretty much a no brainer...IF you get everything in place first,
I'm very happy with my Corsa system.
Old Aug 5, 2016 | 09:15 PM
bob arrowsmith's Avatar
bob arrowsmith
Default corsa exhaust
which corsa model exhaust did you get, would be nice if you could post some pics and video....
Old Aug 5, 2016 | 09:59 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Take a look at post 13 in the following link.
https://www.corvetteforum.com/forums...post1589226264
I used a similar jack on mine when I did the exhaust. I expect any floor jack could be set up to balance the exhaust on it (or secure the exhuast to the jack). The picture shows where the balance point is.
When I did mine, I supported the exhaust with the jack and rolled it in or out under the back of the car. It went pretty well doing it myself with that method.
PS. Take a look at the good looking '85 in post 6. I had that car for over 25 years.
Old Aug 6, 2016 | 04:35 AM
Christi@n's Avatar
Christi@n
Rear wheels on ramps too?
Old Aug 6, 2016 | 04:59 AM
Joe C's Avatar
Joe C
I did a corsa installation on my 96, myself, w/o help. rear of the car on ramps (my ramps will get the bottom of the car approximately 18 inches off the ground), front held up by jacks (with safety locks and jack stands). I dropped the stock exhaust down in one piece, first by unbolting at the engine, and while supporting the weight, unbolted the mid hangers and muffler hangers, and carefully lowering the one-piece assembly. corsa installation was easier, since it's in several sections, but i did spend a lot of time on getting a perfect alignment.
Old Aug 6, 2016 | 09:05 AM
Christi@n's Avatar
Christi@n
Well
I've spent few hours to think about it.
I ramped car on rear only, and i've got clearance on all parts. Driver side cat bolts i've easily got it from the side of car.
I've tried to unbolt all bolts. No problem exept for driver side cat. I've got them out with heat. No other way than propane torch will work, cause there was a lot of rust on them... So be carefully is a nice idea to avoid to damage them
At the moment i've not a 15mm deep socket to unbolt the top one bolt from the cat driver side. So i will need to buy it. D
Did you make it (top one driver side cat)with 15 mm deep scocket?
I've tried with whrench but it is impossible
Old Aug 6, 2016 | 09:35 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Did mine on jack stands also, take your time once they are tightened up drive it around a few day and readjust if needed. when I was happy with the fit went by a muffler shop and had them welded so I could remove them in one assembly. Good luck
Old Aug 6, 2016 | 09:37 AM
Joe C's Avatar
Joe C
Well
it's been 5 or 6 year now, so I don't remember the details. I do remember un-bolting the cat, and having to rock the exhaust system to un-do the slip joint. my 96 only had about 25K miles, and it was fairly rust free. as I recall, it came apart without much effort.
Old Aug 6, 2016 | 11:55 AM
Christi@n's Avatar
Christi@n
Do You remember need to trim passenger side head pipe cause too long mtwoolford post #4 said this
Old Aug 6, 2016 | 11:58 AM
Joe C's Avatar
Joe C
FWIW, I did not have to trim anything. as I recall, I was somewhere around 1/8" from right to left from being the equal length.
Old Aug 6, 2016 | 11:59 AM
Christi@n's Avatar
Christi@n
I have one more doubt about it.
Corsa instruction sheet says to tap with no mar hammer, to get out passenger side head pipe.
Where should I hammer on it?
And how hard is to get out that part?
Old Aug 6, 2016 | 01:26 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
No trimming, but I put headers and high flow cats on at the same time. if things fit to tight clean the ares with 220 wet/dry paper.
Old Aug 6, 2016 | 02:51 PM
Christi@n's Avatar
Christi@n
What did you gain with high flow cat?
Old Aug 6, 2016 | 03:02 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Hard to say I had a complete P&P done, tune Long tube headers and Corsa. Went from 326rwhp to 424rwhp. was told the cats only effect it by 2-5 rwhp. but I had to have them until this year. This is an LT5.
Old Aug 8, 2016 | 03:08 PM
Christi@n's Avatar
Christi@n
Just finished...😜🍻
Just I've failed to get the right alignment...I don't get how to do it...if I push muffler all the way in hanger... Somewhere a pipe will not well inserted in..,
Old Aug 8, 2016 | 03:40 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Can you split the difference, move one in a bit and the other out a bit? How do you like the sound?
To Corsa exhaust installation tips
Old Aug 8, 2016 | 06:09 PM
Christi@n's Avatar
Christi@n
Will try to do it. Just what is a right alignment in this case? Chrome tips equally stick out from rear bumper? I thought instead there was more something about center muffler and head pipes? I Don't get it.
Sound seems to be good. I say "seems" cause inside cabin even w/o t-top it is not so much louder, so I don't have yet it appreciate from the outside.
Anyway if I'm inside tunnel or in the downtown (between builds) Pushing on throttle I can hear a nice sound fron walls echo
Old Aug 8, 2016 | 06:22 PM
Christi@n's Avatar
Christi@n
There's another problem alignment apart.
Center muffler touch diff. I don't remember if stock exhaust touches too, as far as I remember I would say no.
Do you have this trouble??
Old Aug 8, 2016 | 06:31 PM
Christi@n's Avatar
Christi@n
More pics catcon
