Header Heat Issues
Old Sep 11, 2002 | 11:43 PM
WHRITZY's Avatar
WHRITZY
Default Header Heat Issues
I recently had my motor on my 90 built to include headers. My brakes went out yesterday and I figured it was the booster. Took it in and sure enough it was. What is unusual is the mechanic advised he felt like the heat from the headers caused the booster to crack on the bottom outside....unusual. My problem is that the headers are ceramic coated, and there are several parts closer to the header that have not failed, i.e. plug wires, wire looms, plastic ties, etc.....the booster is a good 12 inches from the header! Has anyone with headers ever had this happen??? Have you ever heard of a booster cracking from the outside on the bottom? :mad
Old Sep 12, 2002 | 02:31 AM
drive it's Avatar
drive it
Default Re: Header Heat Issues (WHRITZY)
Actually my booster melted a hole!!! I just fabbed up a heat sheild in that area and also by the starter out of sheet metal and that solved the problem.
Old Sep 12, 2002 | 02:43 AM
pablocruise's Avatar
pablocruise
Default Re: Header Heat Issues (drive it)
I did the same as Drive.
Fabbed a shield. (also parts of my headers are wrapped with the fiberglass tape)
small tip: Spraypaint plug boots with high heat spray paint.
Old Sep 12, 2002 | 10:52 AM
Nathan Plemons's Avatar
Nathan Plemons
My ceramic coated headers have never caused a problem. I've got plug wires that run within a quarter inch of them and don't even try to dry out or crack.
I guess the L98 booster is closer or larger? I've got L98 headers and don't have any trouble. :confused:
Old Sep 12, 2002 | 11:30 AM
WHRITZY's Avatar
WHRITZY
Default Re: Header Heat Issues (Nathan Plemons)
I think what's happened is that the side/bottom of the booster (which is plastic) gets soft from the heat....and when it cooled down it cracked. The new booster is on, and I put my hand on the side of it near the header and get scalded! But, you're right, I have plug wires, etc that are closer to the header than the booster, and they're ok....
89 Joe, you and I have about the same thing going on in our car other than you chose the superram....is there any chance either of you guys that fabricated a shield can send me a pic so I can get an idea of what you did?
Have to go to track Sunday, so am on the way to parts store to see if I can get some heat tape or something to put on the side of booster as a temp fix and keep some of the heat off it..... :(
Old Sep 12, 2002 | 11:31 AM
WHRITZY's Avatar
WHRITZY
Excuse me Paul...I meant "89 Paul"
Old Sep 12, 2002 | 08:50 PM
WHRITZY's Avatar
WHRITZY
Hopefully have the problem solved. Went to speed shop today and purchased an alumized heat barrier blanket. Cut myself out a circle, removed brake fluid reservoirs, and wrapped booster in it. Gathered the whole thing at the back, fastened with a plastic tie, trimmed off excess and I doubt she'll ever melt again!
Thanks for the responses!
Old Sep 13, 2002 | 12:39 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
I had my booster split on the outside bottom part like you describe.
I don't have headers though. OEM manifolds here... :)
IMO headers may speed up this process but I suspect having this happen is normal wear and tear for a car with a plastic brake booster.
Old Sep 13, 2002 | 12:47 AM
93LT1's Avatar
93LT1
I second Nathan. I've had the ceramic coated headers for over two years and plug wires and booster are non issues..fingers crossed.
Hank
To Header Heat Issues
