87 Convertible Power Seat Issues
Old Aug 8, 2016 | 02:01 PM
76yellow's Avatar
76yellow
Default 87 Convertible Power Seat Issues
I bought my 87 Convertible 7 or 8 years ago.It has a "Flood Title" but has been a great car and looks great, runs perfect etc. I finally decided to see why the seats don't work. I can see by the flood residue on the frames that they were apparently under water. Thats hard to believe because the carpet is original & looks fine. I put power to all of the motors & they all work. I cleaned all the connectors I could find. The only function that works is the drivers seat back tilts forward & back. My question is are there some connectors or grounds under the carpet that I have to get to ?Both seats are back all the way so was never an issue. Its just something I would like to fix !
Old Aug 8, 2016 | 04:03 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
ill be doing this in the winter on my 87. i have the fwd motion working 1% of the time. subbed.
Old Aug 8, 2016 | 07:55 PM
76yellow's Avatar
76yellow
Looks like I'm not going to get much response !
Old Aug 8, 2016 | 08:40 PM
VikingTrad3r
Oil Producer
if your motors function, then its either switch or wiring. put 12v up from switch then test downside of switch for 12v. then look for cut wires between switch and motor.
Old Aug 8, 2016 | 11:19 PM
WVZR-1's Avatar
WVZR-1
You guys very likely need transmissions, cables etc.
Name:  early electric seat adj.png
Old Aug 9, 2016 | 07:48 AM
76yellow's Avatar
76yellow
To 87 Convertible Power Seat Issues
