pressure cycling switch on 85
Old Aug 11, 2016 | 12:50 PM
85vegasvette's Avatar
85vegasvette
Default pressure cycling switch on 85
well found the headach for the ac, played aroiund and just ahppened to touch the pressure cycling switch and the compreessor kicked on, paper clipped the plug and it worked, but when i attach the plug to the switch i have to jiggle it to work, my question is do i need to evacute the system to change the switch, it sure is nce having ac again..lol
Old Aug 11, 2016 | 12:58 PM
antfarmer2's Avatar
antfarmer2
Not sure but believe it will screw off without loosening charge.
Old Aug 11, 2016 | 01:22 PM
Churchkey's Avatar
Churchkey
Switch screws on to a Schrader valve fitting = no loss of Freon when changing the pressure switch.
Old Aug 11, 2016 | 01:50 PM
85vegasvette
Woooo Hooo, finally an easy issue....lmao
Old Aug 14, 2016 | 10:56 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Old Aug 14, 2016 | 11:35 AM
85vegasvette
Originally Posted by FOURSPEEDVETTE
Yes autozone $11.99 and its ice ice baby....should have changed that before the conversion 2 years ago...probably was the only issue....lol
Old Aug 14, 2016 | 12:04 PM
antfarmer2's Avatar
antfarmer2
good job
To pressure cycling switch on 85
