Removed air pump, air control valve question
Old Aug 14, 2016 | 12:21 AM
BlueTwoToneCorvette's Avatar
BlueTwoToneCorvette
Default Removed air pump, air control valve question
Hi, I removed the air pump, associated plumbing and got new headers for my 85. There are two air control valves on the front of the engine, each with a solenoid control wire and connection. I removed the air control valves also.
Can I just tape these connector wires off or is there a signal going back to the ECU that I need to worry about?
Thanks.
Old Aug 14, 2016 | 07:30 AM
mlm0's Avatar
mlm0
On my 89 I just taped them off. No code
Old Aug 14, 2016 | 01:04 PM
BlueTwoToneCorvette
Thanks, I was thinking I could do that but didn't know for sure.
Old Aug 14, 2016 | 01:09 PM
BlueTwoToneCorvette
Also, I haven't purchased an air pump replacement pulley assembly yet. I am thinking of buying the TPIS one, but I think $170 for a bracket and plastic pulley seems pricey.
I have heard of gutting the old pump and using that but I'm not sure how that works long term, plus it's ugly.
I don't know if I could build one myself, any other cheap options?
Old Aug 14, 2016 | 07:26 PM
mlm0's Avatar
mlm0
I bought used one off this site in great condition for 80.00. If you use gutted pump you still will have that mess under hood If you arn't using pump I would remove air deverter system also which includes tube down to cat. Don't forget to plug exhaust manifolds
Old Aug 19, 2016 | 11:48 PM
Guro305's Avatar
Guro305
I did exactly that on my 86 Trans Am. Never put a pulley or gutted the pump at all either. Never had any issues.
Old Aug 22, 2016 | 04:50 PM
BlueTwoToneCorvette
I installed the TPIS pulley. It's expensive, but very nice finish and weighs almost nothing.
To Removed air pump, air control valve question
