Cold Start
Old Aug 17, 2016 | 08:05 AM
whitemj1948's Avatar
whitemj1948
Default Cold Start
I have a bone stock (as far as I know) 89 coupe, with 145,000 miles on it, that runs rich on cold start, rich enough that it will bring tears to your eyes. If you let it run for 5 minutes or so it will lean out and run as it should. I think I have read on the forum that a bad O2 sensor will cause this. I just want to bounce this off of you guys to see what your opinions are. Thanks in advance for your thoughts.
Old Aug 17, 2016 | 03:34 PM
Kevova's Avatar
Kevova
Normally a code 13 should set for O2 not ready. If you have a way to monitor data I would make sure CTS is reading correctly a long with O2 sensor activity. O2 or coolant sensor could cause condition but with no diagnosis it is a guess
Old Aug 17, 2016 | 08:48 PM
aklim's Avatar
aklim
How would the O2 sensor do this? You shouldn't be in closed loop in 5 minutes, should you? IIRC, the O2 sensor data is not even used outside of closed loop. If this is correct, it shouldn't matter.
A couple things I would check are the IAC on the throttle body. If it has crud blocking the "air leak" it might explain it? The other is the health of your injectors. If they are crudded up, the spray pattern might not be good and thus have a less than ideal combustion?
All this is assuming your timing is correct and CTS that the ECM sees is correct. To know that, I would time it at 6 degrees. Also, I would use an infra red thermometer and hit the sensor to see what it reads as cold and use a scanner to see what the ECM sees. They should be kinda close to each other.
Old Aug 18, 2016 | 03:03 AM
Cliff Harris's Avatar
Cliff Harris
The O2 sensor doesn't do anything until the ECM goes into closed loop mode. Actually that's not exactly true. The ECM waits for the O2 sensor to start working before it goes into closed loop mode.
Conditions for closed loop mode:
Coolant temperature > 40.7°C = 104.4°F
Engine run time > 300 seconds (cold) if startup coolant temperature < 58.5°F
Engine run time > 206 seconds (warm) if startup coolant temperature > 58.5°F and < 158.5°F
Engine run time > 50 seconds (hot) if startup coolant temperature > 158.5°F
Oxygen sensor reading between 0.195 and 0.686 volts for > 10 seconds
300 seconds = 5 minutes. Does that number seem familiar?
Old Aug 18, 2016 | 06:33 AM
aklim's Avatar
aklim
For whatever reason, I seem to have 148 in my mind. I only idle the car in winter and it does take more than 5 minutes to get into closed loop even with the O2 sensor being a heated one.
Old Aug 19, 2016 | 02:06 AM
Cliff Harris
That's the temperature in my 1986 BUA EPROM. I checked the calculation to make sure. Other years/EPROM versions might be different.
Old Aug 19, 2016 | 05:27 AM
aklim's Avatar
aklim
Or it could be that my programmer decided that was best since he wrote the program
Old Aug 20, 2016 | 01:38 AM
Cliff Harris
Programmers do what they think will give the best results for you and your setup.
Old Aug 20, 2016 | 02:01 PM
whitemj1948
Thanks guys for the responses, I got to thinking today (gets me in trouble) and I have never checked the timing on this car. Well low and behold it was set at 8 degrees, set it back to 6 now the car starts as it should cold or hot. Thanks again.
Old Aug 20, 2016 | 02:33 PM
aklim's Avatar
aklim
I would have thought that 2 degrees wouldn't have made such a difference. I would certainly paint a stripe on the harmonic balancer to see if it moves. On the older cars, the balancer has a habit of separating.
To Cold Start
