Thinking Ahead
Old Aug 18, 2016 | 01:31 PM
dsimon55's Avatar
dsimon55
Default Thinking Ahead
Starting to think ahead. With winter around the corner my car will go into storage.
Anyone have any suggestions on a trickle charger to keep the battery in good shape.
Would love to find something that has quick connects.
My car is a 1985 with battery up front
thanks
Old Aug 18, 2016 | 02:12 PM
daverulz's Avatar
daverulz
I use the Deltran Battery Tender. Pretty much the standard for this as far as my research showed. It came with both clip on and ring terminal leads and a quick disconnect. I've been very happy with it. There are cheaper options, but not much cheaper. When I bought mine a year or two ago I think it was only $35 (prices fluctuate on amazon).
https://www.amazon.com/Deltran-Batte.../dp/B00068XCQU
Old Aug 18, 2016 | 02:18 PM
brushmor's Avatar
brushmor
+1 to the Deltran. I got the JR that puts out 750mA and it's worked great for for years now.
Old Aug 18, 2016 | 02:34 PM
MitchV's Avatar
MitchV
I use the Deltran Jr as well. No problems.
Old Aug 19, 2016 | 04:25 PM
hcbph's Avatar
hcbph
I'm going to be the Devils Advocate here: Either a battery cutoff or unhook the negative battery cable. It's a little hard for varmints getting where they shouldn't, chewing on something they shouldn't and starting a fire if the battery isn't connected. They can make a mess of things but it won't burn the car or garage down while you aren't home especially. I've been using a battery cutoff and/or rehook the negative battery cable back up and run the car every 30-45 days has not been a problem for me on either of the cars I put in storage yearly. Doing this pretty much back into the 70's and not had an issue with it
If you have a decent battery, I've started a vehicle when it's been -30 outside as long as it's been started on a regular basis for sufficient about of time (I let it warm up when I do it).
Old Aug 19, 2016 | 06:51 PM
Purple92's Avatar
Purple92
While the Battery Tender is probably the most commonly used maintainer - I use the Ctek charger (they make several with the maintenance function), and I can highly recommend it. Some of the Ctek's also have a rejuvenate feature - opinions on how well it works vary - but I've used it and think it does "help" a older battery live a bit longer. I've lent mine to several people - and the opinions are also mixed - but generally positive.
I will recommend against one of the very inexpensive import battery maintainers - I had one hooked up to a "spare battery" a few winters ago - and when I checked the voltage one morning - it read 14.8 volts - WAY too high for maintenance use.
Old Aug 19, 2016 | 07:11 PM
c4cruiser's Avatar
c4cruiser
I've been using the Deltran Battery Tender JR on my c4 and C5 with no problems. That unit comes with both the alligator clips and ring terminal connectors. There is a connector on the cables so either type of connection can be used.
On my C5, I use the ring terminal connectors. The positive ring terminal is connected to the B+ post at the underhood fuse box and the negative ring terminal is connected to the negative battery cable end. The short lead is easily placed along the various harnesses and is out of the way when I'm driving the car. The harness is long enough that it will extend out of the engine compartment and connect to the charging unit cable
I use the alligator clips on the C4 as it's easy to get to the side terminal bolts and the hood will close without touching the clips.
Old Aug 19, 2016 | 09:11 PM
HAD2HAV2's Avatar
HAD2HAV2
CTECK. I've used one for at least 5 years. It has double duty on 2 cars, one car for 2 weeks the other for 2 weeks during the winter. My sister bought a new 07 C6 and use to complain of dead batteries. I bought her one for Christmas several years ago and I have not her complain about the battery. She only has 25,000 miles her 07.
To Thinking Ahead
