what is this light?
Old Aug 31, 2016 | 08:37 PM
Sid.123's Avatar
Sid.123
Default what is this light?
Old Aug 31, 2016 | 08:39 PM
Sid.123's Avatar
Sid.123
this clear lense has a 21w bulb in it but I cant seem to find what switchs it on...the orange indicator/marker light works ok...thanks
Old Aug 31, 2016 | 08:47 PM
s carter's Avatar
s carter
Cornering light. car on, headlights on, turn on Directional it should lite with the side you would be turning goes out with Directional when turn is done.
Old Aug 31, 2016 | 09:03 PM
hcbph's Avatar
hcbph
Old Aug 31, 2016 | 09:04 PM
Sid.123's Avatar
Sid.123
ok great,thanks...is that the same for the one on the rear wing?
Old Aug 31, 2016 | 09:07 PM
WVZR-1's Avatar
WVZR-1
I believe you mean in the rear bumper fascia and that's a B/U (reverse lamp), key-on, headlamps on and the car in REVERSE - BOTH on the rear next to red s/marker should light.
Old Aug 31, 2016 | 09:08 PM
s carter's Avatar
s carter
Those are Reverse Lights, Key on/car running car in Reverse they should light, along with the two smaller lights by Lic. plate
Old Aug 31, 2016 | 09:10 PM
Sid.123's Avatar
Sid.123
thanks...this forum is the best...thanks guys
To what is this light?
