Mail order tune
Old Sep 12, 2016 | 01:53 PM
steven mack's Avatar
steven mack
Hi Tequilaboy, is this the right orientation of the chip and chip adapter that I got from you? The prom is on the bottom of the adapter.
Old Sep 12, 2016 | 03:32 PM
tequilaboy's Avatar
tequilaboy
That is correct. Be sure that the memcal is also plugged in to the adaptor, but assume that is what you mean by prom is on the bottom of the adaptor.
I have programmed the (4) eeproms with the 24.5 lb injector constants as discussed. Each is progressively richer in PE mode relative to the baseline bin.
1 Baseline tune approx 6% richer in PE as compared to stock.
2 +4% enrichment in PE. BPW pulse width cap fix added to ensure sufficient pulse width.
3 +8% enrichment in PE. " "
4 Max enrichment in PE . " "
I reprogrammed eeprom #1 to fit between #3 and #4 and relabeled it as #5.
So you should have eeproms numbered 2-5.
These bins should bracket the fueling requirements. I"ll send you the text files with more detail.
Old Sep 12, 2016 | 04:01 PM
steven mack
Thanks Tequilaboy ,memcal is what I meant.The memcal is at the bottom of the adapter.The memcal has three tabs on it one facing toward the top the other two facing toward the bottom.When I put the memcal in the adapter with the one tab facing up.If I'm explaining it right.I was wondering where I put the number one chip.Now I now there were only four chips.Thanks,Steve
Old Sep 12, 2016 | 08:04 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
To be sure you are clear on terminology...
Memcal is the multi-micro-chipped board that replaces your factory "Memcal".
The "adapter" piggy-backs onto the Memcal.
A single chip plugs onto the adapter. It sounds like TBoy burned multiple chips for you...for you to select from. Only one can be used at a time.
If you have access to a local dyno, you can run one, look at the AFR during WOT, then decide if you need more fuel. Sounds like #3 would be the richest....#2 the leanest?
Pictures of a Memcal/Adapter combo. The one pictured just doesn't have the cool clamp-lever
http://support.moates.net/g1/
Old Sep 12, 2016 | 10:38 PM
steven mack
GREGGPENN thanks for the info,Steve
