Installed Edelbrock Pro-Flo XT
Old Sep 11, 2016 | 10:34 AM
RWDsmoke's Avatar
RWDsmoke
Default Installed Edelbrock Pro-Flo XT
I just finished installing this manifold. No hood clearance problems. I bought an ls1 throttle body on ebay with sensors, the ls1 throttle body sensors only require a pigtail change. It does require a small cap distributor which I had already had. It has a bracket for an ls1 MAP sensor, I already converted to speed density with my EBL Flash. Now I just need a little bit of tuning for a lean spot off idle, other than that it runs really good. I'm happy with it so far.
Old Sep 11, 2016 | 11:37 AM
ddahlgren's Avatar
ddahlgren
Looks good who makes the air pump eliminator bracket?
Old Sep 11, 2016 | 03:45 PM
RWDsmoke's Avatar
RWDsmoke
It was fabricated by a friend.
Old Sep 11, 2016 | 04:35 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
what are the rest of the engine specs and how does it pull down low compared to a TPI.
Old Sep 11, 2016 | 05:01 PM
ddahlgren's Avatar
ddahlgren
Nice job well thought out!
Old Sep 11, 2016 | 08:38 PM
RWDsmoke's Avatar
RWDsmoke
It has a hotcam and fastburn heads, 10.76 CR. 1 3/4 LT headers. I bought the car 12 years ago with no motor. I had a vortec truck motor with a modified lt4 intake. I never had a TPI on it so I can't compare them. It pulls ok above 1k and comes on strong above 1.5k. Really strong above 4k up to my rev limiter at 6.2k.
Old Sep 11, 2016 | 08:42 PM
eutu1984's Avatar
eutu1984
Thanks that info was very helpful, i have been considering the proflowXT but I am not sure if I want to give up bottom end torq.
Old Sep 12, 2016 | 09:59 AM
cv67's Avatar
cv67
St. Jude Donor '05
If youre running on a stock tune a good one will really wake it up youre moving a lot more air than stock
Old Sep 12, 2016 | 10:31 AM
Kevova's Avatar
Kevova
Are you running drive by wire or cable? Couldn't tell for sure in pix.
Old Sep 12, 2016 | 10:52 AM
coothethird's Avatar
coothethird
Nice to know this intake fits under the hood. A little off topic, but how are you liking the ebl flash?
Old Sep 12, 2016 | 11:19 AM
RWDsmoke's Avatar
RWDsmoke
Cable. Throttle body is from early ls1 truck.
Old Sep 12, 2016 | 12:48 PM
ddahlgren's Avatar
ddahlgren
Stick or auto as wondering how to do TV cable for a 700R4 with this.
Old Sep 12, 2016 | 01:57 PM
RWDsmoke's Avatar
RWDsmoke
I have a 6 speed. There is a company that makes an adapter plate to use the stock l98 throttle body. Then you can use the stock throttle cable too. I used a longer Lokar cable made for the ls1 throttle body.
Old Sep 12, 2016 | 02:10 PM
RWDsmoke's Avatar
RWDsmoke
I like the ebl flash. The open loop ve learn with a wide band gets your fueling close really fast. I load several bin files adding one or two degrees timing each time and switch between them while driving. It does everything I need it to do. With no maf sensor I ran a 4 inch tube from the throttle body to the sheet metal fabricated air filter housing, no restriction.
Old Sep 12, 2016 | 02:16 PM
383vett's Avatar
383vett
This picture doesn't show it well, but my throttle bracket has room for the throttle cable and two others (could be cruise control or tv cable). I have been running this for decades and possibly was a holley part back then.
Old Sep 13, 2016 | 11:23 AM
ddahlgren's Avatar
ddahlgren
Sure looks like a mini ram and not an XT to me.
Old Sep 13, 2016 | 12:05 PM
383vett's Avatar
383vett
Very astute. I assumed the Edelbrock used the same throttle cable.
Old Sep 13, 2016 | 12:24 PM
ddahlgren's Avatar
ddahlgren
Uses a LSX throttle body from all I have seen big round hole LOL..
Old Sep 13, 2016 | 03:12 PM
383vett's Avatar
383vett
Are those cable or motor controlled?
To Installed Edelbrock Pro-Flo XT
