Fans & Temp
Old Sep 13, 2016 | 12:54 PM
CT54531's Avatar
CT54531
Default Fans & Temp
At what temp should the fans come on on my 1987 C4. I've owned it since new and in the past, it seems to me they kicked in in the mid 220's and stayed on till the temp was down to the low 200's or below. Now, they're coming on at 230 and staying on till the temp gets down to about 224-226, then off, then back on at 230. Fan and fan relay both work. Thermostat? Coolant sensor?
Old Sep 13, 2016 | 02:30 PM
antfarmer2's Avatar
antfarmer2
My 94 comes on at 228 and 238. Have you pulled the radiator and give it and the ac coils a good cleaning? Is that by the analog temp?
Old Sep 13, 2016 | 02:35 PM
WVZR-1's Avatar
WVZR-1
These temps are from a "scanner" or you're just interpreting the temps from the IP CLUSTER display? The IP is from a different sender/sensor than that used by the ECM to control the fans and other ECM controlled functions that rely on temp.
Actually the fan behind the radiator is ECM controlled - you said "they're" hinting that you have an AUX forward of the condenser and that is actually controlled by a switch and NOT controlled by the ECM. Which fan(s) are you mentioning?
Old Sep 13, 2016 | 04:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
'87 = all digital. No Analog gauges.
Old Sep 13, 2016 | 05:09 PM
CT54531's Avatar
CT54531
New radiator. All seems in order with that. And did clean the AC coils in the process. Mostly, it just seemed to me to be different than before.
To WVZR1: I'm referring to the display temps. And the "they" was a slip of the tongue having recently worked on my wife's Elantra.
I've occasionally seen references to "resetting" the temp for the fans. Being somewhat committed to the "if it ain't broke, don't fix it" school of thought, is that something to consider/
Thanks for the replies.
Old Sep 13, 2016 | 09:27 PM
WVZR-1's Avatar
WVZR-1
Have the car scanned and check the CTS (ECM) values - you could compare the CTS values to the IP values but don't expect a match, close maybe but no match.
Old Sep 14, 2016 | 03:13 AM
Cliff Harris's Avatar
Cliff Harris
Those are the standard "fan on" temperatures. I don't know offhand what the turnoff temperatures are.
The main fan is controlled by the ECM. The auxiliary fan is controlled by a coolant temperature switch in the driver's side head between spark plugs #1 and #3.
Old Sep 14, 2016 | 01:48 PM
CT54531's Avatar
CT54531
Thank you all.
To Fans & Temp
