Heater core by-pass question
I was going to by-pass the heater core, but notice if I do that there is only a 1/4" +/- alum fill tube going to the radiator. So how would you fill it. I have a DeWitts radiator, with no cap other than the black expansion tank.
Just wondering what others have done....
A 421 is gonna be one immense engine to cool and your gonna need every trick in the book to do it, and bypassing the heater core ain't one of them.
The small block chevy had a bunch of compromises built in it that compromises it's ability to cool the engine, and no, it's not bad engineering per se, just imagine some poor farmer in Minnesota trying to star his work truck at 4 a.m. and thirty below.
To cool that beast, your model will be the race engines, when NASCAR and other sanctioning bodies actually used "stock" engines and you're far, far, from being there.
I would have liked to use the electric pump, because of hot weather traffic. Plus in Florida it's freakin hot! And it's black! If I ever go full on Race Car, I'll take off the a/c and put the electric pump on it.
Thanks again for the reply.
" One of the latest developments is the Stewart Stage IV pumps (with this type impeller..other manufactures offer the same or similar) made possible by CNC machining...This impeller almost doubles coolant flow while consuming less horsepower than conventional impellers".
What you really need to consider is plugging the bypass hole ( the third hole on the passenger side water pump mounting area on the block)...again allow me to quote:
"...improved cooling efficiency results when this bypass hole is plugged ...(some high po water pumps come with the corresponding hole in the water pump body already plugged)...and four holes typically 1/8th inch in diameter ate drilled in the thermostat....(or a restrictor plate ala circle track racing is used in place of a thermostat)...Even if everything in the cooling system is operating properly, drilling holes in the thermostat and plugging the internal bypass usually results in a measurable drop in coolant temperature"
from HP Books "SMALL BLOCK CHEVY PERFORMANCE";
I can only add, put a valve in the discharge hose from under the thermostat housing to the heater core...note this is not the same as "bypassing the heater core"; it merely forces that hot water which otherwise does nothing but transfer heat into the dash/cockpit, into and through the radiator where beneficial cooling can occur...open the valve if it ever gets cold in Florida.
I already drilled 4 holes in the thermoatat, I did this for "burping". I will plug the hole on the pump before the install.
Liked the idea of the electric pump because in traffic it would have better flow. Here in Florida, heat is crazy plus high humidity.
Thanks very much again
