Hesitation
Old Sep 13, 2016 | 11:44 PM
SQue's Avatar
SQue
Cruising
Default Hesitation
I have a 1994 LT1 6 speed, several weeks ago I developed a stumble while accelerating, felt like trash in gas, changed gas filter and ran sea foam in a full tank. Problem continued, no codes, worse when accelerating from a dead stop and shifting gears, it is intermittent while accelerating and still pulls strong. Any help would be appreciated.
Old Sep 14, 2016 | 01:17 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Get a fuel pressure gauge, tape it to windshield facing in and observe fuel pressure during symptoms. Report back findings and search forum for fuel related hesitation.
The strategy is to eliminate the easiest stuff first. Vt
Old Sep 14, 2016 | 03:32 AM
Cliff Harris's Avatar
Cliff Harris
I have seen those symptoms with bad spark plug wire(s).
Old Sep 14, 2016 | 05:52 AM
antfarmer2's Avatar
antfarmer2
Change the front two o2 sensors.
Old Sep 14, 2016 | 11:05 AM
aklim's Avatar
aklim
Me too. Get the engine started and spray a fine mist AROUND the wires in a dark garage and see if anything lights up. Repeat for when it is hot.
Old Sep 14, 2016 | 04:51 PM
SQue's Avatar
SQue
Cruising
I changed the O2 sensors last weekend, got a little better. I was thinking plugs and wires next but probably need to check fuel pressure first. If it was bad Opti would it throw a code?
Old Sep 14, 2016 | 06:37 PM
antfarmer2's Avatar
antfarmer2
You just jinxed yourself.
Old Sep 14, 2016 | 06:53 PM
SQue's Avatar
SQue
Cruising
I knew it after I said it!!!
Old Sep 14, 2016 | 10:31 PM
raya123_2000's Avatar
raya123_2000
Default My 1990 Blk 6sp had same problem it was the fuel Pump
My 1990 had same problem. I was going to give it a full tune up when I got back from vacation. Left the car for a month, battery off covered in the garage. When I got back car wouldn't start. Fuel Gauge showed no presure. Checked relay, replaced pump and filter. She runs like new no hesitation on hard acceleration.
Old Sep 16, 2016 | 02:45 PM
SQue's Avatar
SQue
Cruising
Ok guys, finally had a chance to check fuel pressure, turn key on it shoots to 45psi, then drops to 40psi, start it and drops to 35psi, turn it off and rises back to 40psi.
Old Sep 16, 2016 | 03:13 PM
aklim's Avatar
aklim
Kinda rapid drop. WOT pressure?
Old Sep 17, 2016 | 01:15 AM
VikingTrad3r
Oil Producer
can you drive around with it taped to the window to observe any fluxuations during the hesitation symptoms. just want to rule it out fully and move on.
also, does it do it right away from cold start in the morning or only after its been warmed up (helps guide toward open\closed loop)
Old Sep 17, 2016 | 09:23 PM
SQue's Avatar
SQue
Cruising
Haven't had a chance to work on it today.
It does it from start, hot, cold, all the time.
Old Sep 17, 2016 | 09:28 PM
aklim's Avatar
aklim
Perhaps so but when the demand is highest, can it deliver? If not, what other points can it not deliver? Delivery at idle is good but if it can maintain pressure all over, that is better.
Old Oct 12, 2016 | 01:31 PM
SQue's Avatar
SQue
Cruising
Update: Changed plugs (NGK iridium) and wires (Taylor 8mm) last weekend. Ran great but noticed today it is doing same thing from idle! .????
Old Oct 12, 2016 | 01:56 PM
Indio Monk's Avatar
Indio Monk
I am trying to trouble shoot my rough idle also. What did your old plugs look like? I am going to follow your thread and wish you luck.
Old Oct 12, 2016 | 03:22 PM
SQue's Avatar
SQue
Cruising
Plugs were not bad at all. I had a bad wire on the passenger side.
To Hesitation
Old Oct 12, 2016 | 08:58 PM
lt4obsesses's Avatar
lt4obsesses
Check the fuel pressure regulator. Pull the vacuum line and look for signs of gas.
Old Oct 12, 2016 | 09:56 PM
SQue's Avatar
SQue
Cruising
Pulled vacuum line from regulator, dry.
Old Oct 12, 2016 | 10:58 PM
desertmike1's Avatar
desertmike1
How Long have you had this car? How many miles on the clock? Has the Opti been changed out, and if so by what Brand opti? When you had the plugs out did you run a compression check? Have you ever washed down the engine with water? Has the engine been overheated in the past? do you still have the old plugs, and did you keep them in order by cylinder removed?
