LT1 noises on video - lifter or injectors or bent rod
Hope you guys are doing good. I'm new to the C4 and new to the LT1. Here are some noises that worry me. There are 2 noises, 1 video for each
FIRST a "wob wob wob" Took the video at about 150 F a couple minutes after start up.
SECOND is like a fast "tih-tih-tih" and first noise is gone from what I can tell. I took it after a 12 minute drive
I spent 4 to 5 hours researching this but I'm still trying to narrow it down. It could be dirty oil, dirty or bad lifters, dirty or bad injectors a bent rod or worn cam lobe?? The oil was changed 500 miles ago from 5W30 to 5W30 synthetic. Engine performance is good, start up is good.
The second noise seems to be coming from where I mostly had the camera. I just learned how to change brakes and I also just learned what a lifter is so I will end up taking it to a shop but Im hoping you guys can help me understand this potential problem better. I am learning as much about the C4 and LT1 as I can and want to take very good car of this car.
Is this true? If its a bad lifter, the lifter roller bearings can fail or even disintegrate which will obviously cause engine damage. Thank you for the help.
Maybe this thread can help and guide you on what to look at. The noise is very similar.
Today, 2000 miles after, my car runs even better but still hear the noise. I do not worry anymore and that´s good for my mental health....
https://www.corvetteforum.com/forums...ine-noise.html
It sounds similar to my LT4 earlier this year and it turned out to be a bad lifter. Use a long screwdriver or a length of dowel and put one end on a valve cover bolt closest to the noise and one end against your ear while the engine is running. Listen for a loud, distinctive ticking noise. Repeat for all the other valve cover bolts to determine if one area sounds louder than the others. That will determine if it is a valve-train related issue. Best case scenario is that it is a bad lifter, worst case is that a cam lobe is going bad.
From what I hear, you can probably continue to drive the car unless the noise starts to get louder.
If you're feeling adventurous, you can try one of the oil additives which claim to free up sticking lifters, otherwise, be prepared to shell out some money. The lifters themselves aren't that expensive, but there's a lot of labour required to get to them.
woodstockdrifter (09-15-2016)
The first sound is exactly what my 95 sounds like at start up and until it reaches operating temp. When I first bought my car 5 years ago, I took it to show a friend of mine who is a very good mechanic. He heard it and said it was an exhaust manifold leak likely from a cracked manifold. He said he had seen quite a few of the right side manifolds crack, usually it's under the heat shield and you can't see it until you remove the manifold . It hasn't bothered me since and I've put probably 40,000 miles on it since I bought it. If I were to ever feel super froggy I might replace the manifold and go with headers. But that's not really in my crystal ball for the future.
I know not what we want to hear but if its there we need to address it.
After more research and reading threads like this one
https://www.corvetteforum.com/forums...licking-3.html
I realize I have 2 different problems from 2 different noises. I am going to address noise 2 first since it seems more serious.
I don't think its an injector because engine performance has been fine at all rpms. So it could be a bad lifter, bad cam lobe or bad rod. But I've been hearing more youtube videos and leaning towards a bad lifter. So here is my plan:
Is there any device I can use to help diagnose this like a OBD1 reader? If I take it to a shop will they do manual checks or hook up the ECM to their tools? And last thing, how does this happen?? Do lifters just go bad or does something cause them to go bad?
- Try screwdriver listening method
- Check oil for dirt and pressure
- Possibly try oil additive
- Possibly remove valve cover for further diagnoses
- Take to a good shop
I think I remember seeing your thread as I searched. Thanks for the link. I think your second video and my second video have pretty similar noises but mine is at a faster rate. I think you should worry and look into it again because the more I research, the more I understand how the noise can be a sign of future engine damage. If its a bad lifter it can cause engine damage.
I can´t think what else to do but to enjoy my car.
In the process of putting headers on and removed the old manifolds. Both drivers and passengers manifolds were cracked in two different places. They looked identical. This pic is after I cut off the heat shield.
Anyway, that's the cause of the burble sound you hear.
It's only taken me three hours to get the old manifolds off! Now the fun begins.
Attachment 48034367
Attachment 48034367
Pro Mechanic
I don't see any soot by those cracks so my first thought is that in spite of the fact that they are cracked...I doubt that they're leaking.
The first noise, the wob wob wob goes away after the car's warmed up. The second noise, the ticking starts when the car is warmed up.
I'm looking into the ticking noise first. I will be taking off the valve covers soon I just havent had a chance to do anything with the car besides inspecting the oil filter.
Pro Mechanic
Lash the valves then or use 20-50 oil. I use 2050W dino oil in my 91 for the last 8 years and no leaks and no problems. I doubt the injectors will get noisy from warm oil. If the lifters have leaky check valves they will as oil thins out. The 5 30W was all about startup smog stuff and fleet mileage. 20-50W will easily work with the temps 99% of C4 Corvettes are driven. If you use quality oil an additive is useless BTW. The big deal is keep it fresh and clean. The synthetic oils that allow high mileage between changes if me every 3K I would pull the filter and change it and add to allow for lost oil. Lashing valves and an oil change is about the cheapest test you might have on hand.
Engine feels very strong and sounds good overall but I havent pushed it past 3000 rpm since I first heard the noise. Someone on another forum told me it it wouldnt be a damaged cam because the engine is running too smooth and at least one cylinder would be underpowered. Checked the oil filter yesterday and no metal particles or flakes so probably not a damaged bearing. Well thats all I know when it comes to diagnosing the bearing stuff.
Since I have to replace the valve cover gaskets I will take a look at the rockers.
Pro Mechanic
If so, that would be an exhaust leak.
IMO; the noise that I'm hearing on the videos are;
1. induction/intake noise
2. valve train and injector noise that is typical for an LT1 -my car sounds about like yours does.
Received 3,043 Likes
St. Jude Donor '05
Not sure you have a problem at all
