I would like to know if #14105147 88-90 front spindle uprite will interchange with #18019570 91-96 .I see the electrical conn is different. Al
18019570 isn't a '91+ spindle/knuckle
'90 is NOT a direct interchange, you would have to bore a hole in the backside of it for the ABS sensor to pass through. Here's a 14105147 compared to an 18019572. The electrical ABS sensor on the '91+ is sealed in the bearing/hub. The '90 uses a sensor and a reluctor wheel.
If a person understands the differences and has proper equipment available the earlier could be used.
Hi Thanks for the pictures. I have both units out of the car .I just wanted to confirm if they were physically the same. I am not using the abs sensor.AL
