Lt1 w/lt4 hotcam rebuilt 355 dyno tune
Hey guys,
Finally getting my 96 c4 ce dyno tuned using a dynojet put in Huntington Beach by Steve at powertrain Dynamics. The LT1 has block redone and is .30 over making it now a 355. I installed the Hotcam, 1.6rr, Compcam Pushrods, lunati beehive valve springs, GM extreme duty timing chain, new lifters, and pacesetter mid length headers, and a 2500 stall converter. Wish me luck and I will post results as soon as I am done. Heads are stock but redone with 3 Angle Valve job Appointment is at 1pm pst. Fingers crossed
Hey guys,
Hey guys,
323 rwhp 335 rwt uncorrected
Pulled 323 best pull with 335 torque uncorrected on a hot, humid socal day. Mind you I have cats, and automatic car. Did pretty good...big *** jump from baseline pcmforless terrible tune. PCMfor less got me running extremely lean and was pinging. It was pulling timing and robbing power. I'm so glad I did this. Everyone, mail order tunes are garbage
Received 3,043 Likes
St. Jude Donor '05
Nice job idle sounds stock to boot.
that will be a lot of fun on the st
Wish there was someone local up here that gave honest #s.
JimLentz (09-21-2016)
It looks like the numbers would be corrected up by 2% based on the J607 standard. This was calculated from the numbers printed on the bottom of your dyno sheet.
Thanks bro
Thanks bro! Got a question for you since you seem really knowledgeable....I currently have the stock diff that came with my car....it's a D36 with 3.07 rear end. I want 3.55s in this bad boy but I'm confused about the carrier 2 and 1 or whatever...can't find out info on if I can just pop on new ring and pinion and be done with it....or is it a pain
St. Jude Donor '05
Call Ed at 4 wheel specialties in north hills builds a good rearend... has agreat trans guy been using him for 20 yrs. Hes fair backs up his work
no not a fancy corvette specialty shop . Youll like that cam a lot better with a little bit of gear
Don't forget that the D36 is not as strong as the D44 BUT Zip Corvette sells those modified covers that turns it into a mini-D44. (caveat there is some installation machining needed on the bearing support blocks).
One of these covers is in the future for my car.
