Transmission extension housing replacement
Then I'll see about ordering the Spicer 2-3-9211X yoke.
Also, how much did it cost to get your drive shaft balanced?
I'm probably going to also do the pinion seal while I'm there. I've read of some putting sealant on outside of seal before pressing it in. And then putting sealant on the splines in the shaft to I guess keep oil leaking out past the splines.
But before removing nut. You mark the nuts location to housing and yoke and count number of thread above nut. Then tighten it back to where all the marks line up. Some say the nut is a one use only nut and should be replaced every time. But seems like that's more risk of messing up the pre-load if the new nut wasn't tightened down correctly.
Any particular brand to recommend for the bushing and transmission seal? And also the rear pinion seal?
If he says it's bad or should be replaced, then I'll see about ordering the Spicer 2-3-9211X yoke. And check around with balancing the driveshaft.
Any particular brand to recommend for the bushing and transmission seal? And also the rear pinion seal? Don't know if this is one of those deals best to stick with Ac/Delco GM parts or aftermarket just as good or better than OE.
my bushing and O ring for the tail shaft and pinion seal were all ordered on eBay
But I grabbed the driveshaft to wobble it around to check ujoints, and noticed the yoke wobble around in the extension housing. I figured there's a good chance the yoke is scored i.e. needs replaced. Don't know till removed. I was just thinking of ordering a new yoke along with new ujoints. But I'll probably just wait since at the time I didn't think of also having to have the driveshaft balanced by replacing the yoke.
