As a new 94 owner, the Climate control module looks like the photo below. I guess "Stock" isn't the right wording.... I've seen some fancier "digital" models and I'm wondering if mine is more "base"?
The car is clean, I have the sticker, it didn't have a lot of options, no power seats (I think I'm grateful after reading some threads here) no speakers in the door.. it has an aftermarket stereo so I don't know what it originally had but I do know it had Delco speakers and it does thump pretty good although I haven't found an amp anywhere...
Yours if it's similar to the image you've snagged somewhere is "white" where that's "orange" yes your AC is base/manual AC (C60). The "sticker" you refer to is maybe the SPID and should show C60. If yours is "orange" and it's a '94 it should be the white variety.
Post a snapshot of your SPID (back-side of console door) and it will maybe be easier to ID what was there for a radio.
List is a fairly complete compilation of C4 RPO codes, I don't know that it's complete but a good "quick reference" tool.
You have the better rear axle G92. FE1 softer ride. The sport seats are great but standard work fine too. In fact some argue better. The climate control is manual all the way. This can also be argued as better.
Like anything the complicated options are sometimes overshadowed by simple reiaibility.
Google your options and get to know her better.
The RPO G92 only indicates the car has the "Performance Axle Ratio". The RPO G44 code indicates the installed gear ratio is 3.07. The base axle ratio with the auto trans would have been RPO GM1 which is a 2.59 gear.
