Removing Cats/Precats?
Old Sep 16, 2002 | 04:21 PM
Ender85's Avatar
Ender85
Default Removing Cats/Precats?
Should I remove these? If so, how do I do this?
Old Sep 16, 2002 | 06:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Removing Cats/Precats? (marthpodi)
"Should" is a matter of objectives.
The usual procedure is to replace the front Y with a mandrel-bent unit and the stock main cat with a hi-flow 3-stage cat. These two mods result in more HP and a "sportier" sound.
Old Sep 16, 2002 | 06:47 PM
Lexdog's Avatar
Lexdog
Default Re: Removing Cats/Precats? (65Z01)
Is the front Y pipe advertised in the MAD catalog mandrel bent? :yesnod:
Old Sep 16, 2002 | 07:36 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Removing Cats/Precats? (Lexdog)
I've been wondering this myself.
Old Sep 16, 2002 | 07:46 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Removing Cats/Precats? (FlyboyZR1)
It's mandrel bent, but could use some clean up at the Y joint. I had to return mine as it did not fit. However, have not heard complaints about this recently.
Old Sep 17, 2002 | 02:57 AM
ACEMG73's Avatar
ACEMG73
I just replaced mine with a kit from Eckler's, no precats. So far, so good. I've had it on for over a month with no problems. It is louder, but I like it. Oh, I also passed Illinois emissions with it. Do it! :chevy
Old Sep 17, 2002 | 05:29 AM
65Z01's Avatar
65Z01
I got the mandrel-bent Y from MAD a few years ago and the workmanship was so bad that I returned it and had one custom built at a local exhaust shop.
I too recently easily passed a dyno emissions test in OH with my mods.
Old Sep 17, 2002 | 07:33 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I had no trouble from the Ecklers front 'Y'. It will give you a louder sound in a good way and you also might start getting the dreaded code 32 at highway speeds.
Old Sep 17, 2002 | 07:51 AM
65Z01's Avatar
65Z01
Default Re: Removing Cats/Precats? (joecaver)
I've had no problem with code 32, maybe your EGR Temp Sw (or the insulation on the EGR pipe) should be replaced.
Old Sep 17, 2002 | 10:31 AM
Steel Blue 91's Avatar
Steel Blue 91
I retained the stock Y pipe and had the pre cats removed and replaced with "test pipes" when I had the high flow cat installed. I do have the dreaded code 32 from time to time.
Old Sep 18, 2002 | 09:15 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Is this smog legal in CA.???????
Would do if I could get away with it.
:smash:
To Removing Cats/Precats?
