Lt1 oil pump drive gear upgrade
Having a hard timing finding and upgraded oil pump drive gear for my 93 lt1. Is there such a thing? Or just go with a new stock one. I'm putting a hot cam in and high volume pump and wanna reliable gear in there. Been reading alot about sheered teeth on stockinette after cam/pump change. Thanks.
Look into the composite gear from Comp cams for the distributor and see if it will work with the LT1 oil pump drive. Since the drive gear is hard to replace (Pull intake) I would get the best gear possible in the car especially with a high volume pump.
since the "Hot Cam" is OEM cam a stock gear should be ok. You do want to check how gears mesh when stub is installed. Other mod to consider would be slotting housing to lube gears.
I believe that all LT engines used a 3/4 inch inlet pickup; at least that's what I always got when I purchased a series of oil pumps for my 96. I would suggest that in any case that if purchasing a new pump, also purchase the pickup designed for that pump and that oil pan.
So that coupled with the short 5 year production run for LT engines adds up to a few parts that now command a premium price...like the oil pump stub shaft drive, like the opti, like the water pump and its associated support bearing buried inside the front of the block...
So these are things an LT owner just has to accept and live with..or trade in for an earlier conventional small block pre '92 vette or a later C5...but I would suggest getting that new oil pump drive while the getting is still good.
I don't think they will be able to fulfill your order. They don't have any in stock...perhaps because it's discontinued. That would have been a great option
Lt1 stub shaft oil pump
Has anybody tried using an old hei distributor housing ?? Wack tig done . Maybe , idk seems like it would work. Probably have to have it machined for a bushing or bearing . I know I could come up with something....always do
