Starting problem.
Old Sep 17, 2002 | 02:05 AM
vettewally's Avatar
vettewally
Default Starting problem.
88 vette turns over but doesn't start. Thought it needed gas so added 4 gallons, was not the problem. Not getting any spark at the plugs.Could it be the coil or module or what else could it be. THANKS
Old Sep 17, 2002 | 05:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Starting problem. (vettewally)
If you have pressure at the ruel rail and sure there's no spark, I would suspect the module or coil.
